Question about Soleus KFS-12GW Air Conditioner
My ul-r51m/ce frigidaire remote is for fahrenhigt.but is on celsiush.h..
How can i change my remote from celsius to farenheght temperature.UL-R51M/CE
I want to find a frigidaire control remote UL-R51M/CE
Hey Ralph, thanks for your post!
I see that you need help locating the remote for your Frigidaire refrigerator. In order to better assist you I would need to have your model number. You can locate the model number on the inside wall of the refrigerator. Once I have that information I would be happy to assist you further. -Matt
Apr 27, 2016 | Frigidaire Refrigerators
Tip
Http://www.batteryer.co.uk/ http://www.batteryer.com/ Fast shipping all over the...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Jun 21, 2010 | Computers & Internet
NI996 PANEL CONNECTIONS
N1996 is not a mainboard model number. It is a quality standard code such as CE or UL. You need to provide the manufacturers name and model number if you want answers here.
Jul 08, 2014 | Computers & Internet
Nu merge
Ce inseamna "nu merge" ?
Nu porneste ? nu porneste Windows-ul? Se restatteaza?
Mar 02, 2011 | Toshiba Satellite Pro L300 Notebook
De ce nu pot sa imi deschid mess-ul. imi spune ca este blocat.de ce? imi puteti spune?
sigur a incergat un geniu sati sparga parola .incearca so schimbi
Dec 16, 2010 | Yahoo Messenger
Mp3-mpf-1720
Foloseste CD-ul de instalare. Are nevoie de un driver care se gaseste pe acel CD. L-am folosit pe Windows 7 care il recunoaste singur dar pe Windows XP este nevoie de CD-ul livrat odata cu Mp3 player-ul.
Jun 29, 2008 | Daewoo Pinno VX320 Digital Media Player
Soleus KFS-12GW Air Conditioner Logo
51 people viewed this question
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
