Question about Craftsman 304 FI 95 Amp 120V Flux Core Welder - Red
Mig welder model# 205680 make a rare noise when turn on
When turning on the welder starte making a rare noise like a short circuit
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Take the wire out of the hose to the gun and see if noise stops. You may have a short in the Trigger
Posted on Nov 21, 2013
Why does wire keep coming out when trigger is not pulled
From the mig welder, unplug the trigger leads that exit the mig gun on the end of the gun that connects to the mig welder and power on your machine. If the wire flow stops, you have a shorted trigger circuit inside of the gun cable. If it doesn't stop wire flow, depending on your machine make & model, there is an internal issue with the trigger circuit that could possibly be just a simple relay issue.
Dec 25, 2014 | Welding Tools
My Dayton arc welder model no.3z564 keeps popping the breaker it was working then all of a sudden started throwing the breaker.
take it to an accredited electrical shop that repairs welders as there is a dead short in the circuit.
Oct 29, 2014 | Welding Tools
My mig welder will not make an arc
There is a small chance the transformer burned out, but more likely the switch has dirty contacts or burned out. If you turn the switch through all heat positions 2 or 3 times before you start welding in the morning, it should remedy it in the future. In the short term, spray some contact cleaner (or even WD 40 in this rare instance) into the heat selector switch and rotate it through the ranges a number of times to remove corrosion from contacts.
Will the wire arc when dragged across the ground clamp? If not- there are internal fuses in the machine and they may be loose or blown. There should be one in series with the "hot side" (the gun) of the circuit and sometimes on the ground clamp side of the circuit.
There is a small chance the transformer burned out, but more likely the switch has severely corroded or dirty contacts or the switch burned out.
Jan 03, 2012 | Welding Tools
I have a craftman mig 110v mig welder arc problem
Check to make sure the contact is not touching the nozzle of the mig welder. This would definitely short it out!
Apr 14, 2010 | Lincoln Welding Tools
When you squeeze the trigger on the mig gun, the voltage on the welder drops out. There is no open circuit voltage. What do i need to check
take the gun apart and make sure there are no shorts or lose wires then check the end that plugs into the welder same as above.if all is well we'll have to go deeper.let me know....drum53
Nov 06, 2009 | Miller Welding Tools
I have a Hobart 135 Handler wire feed welder that I purchased in 1993. The problem is when I turn the welder on, it runs just fine. However as soon as I squeeze the wire feed trigger to begin welding, the...
Get a volt meter, go to ohms setting , check transformer to ground for low to zero ohms reading. also look closely at transformer windings for foreign objects in between them, never know what you my find. If transformer is shorted to ground probably time to say some nice words over it before burial. Also just for kicks try a new gun on it, (there is a reason i'm asking you to do(this) see if you can find someone that has spare. A good honest repair shop would probably be reasonable if all else fails. to a least let you know if the transformers a problem. good luck
Signed
Former Miller Certified Tech.
May 01, 2009 | Hobart Handler 140 Mig Welder
Relay clicks, gas blows, rollers dont turn
If you use it regularly, the liner should be replaced about every 6 months. Make sure you get a wiper for the wire. It goes inside the machine, on the wire, just before the feed rollers. It keeps the dust from clogging the liner.
Feb 08, 2009 | Miller Welding Tools
HOBART HANDLER 135 GAS WILL NOT SHUT OFF
It doesn't take much to jamb the solinoid , too much presure on the argon will hold this open, turn the gas off, purge the line, release the pressure on the regulator, Now turn the gas on and put approximatley 2-3lbs only on the gauge, turn the flow meter for a reading of 15-20ltr/min, then try again,
Dec 14, 2008 | Hobart Handler 140 Mig Welder
Craftsman 304 FI 95 Amp 120V Flux Core Welder - Red Logo
277 people viewed this question
Top Craftsman Welding Tools Experts
AZBen
AZBen
Gil Shultz
L Pfaff
L Pfaff
Are you a Craftsman Welding Tool Expert? Answer questions, earn points and help others
