Question about GE JSP69 Electric Kitchen Range
GE JSP69 Electric Kitchen Range Controller Problem
The controller that displays the time, timer, oven temp, etc. keeps going out, when you hit the top of the range it comes back on, but for no reason will go back out eventually. Now it has gone out and won't come back on. Suggestions on what to do to fix?
  • Mike Hayward Oct 07, 2007
    how do you get to the board? I have removed 4 screws underneath the panel and the knobs on the front, but can't remove the face plate. Any trick I should know or screws I am missing?
    you mentioned you could help with the part number. The full model number is JSP69BVBB if you need the MFG # is P1131946NBB. If you cold let me know what part number I need it would be appreciated.
  • 447 Answers
Yes replace the EOC (electronic oven control) after you verify that the board is getting power (no burned wires, no loose connectors) there usually is not a loose wire and the clock has failed. for parts i can help with parts lookup and sourcing if needed will need complete model #
Posted on Oct 07, 2007
  • 1 more comment
  • joey  shearer
    joey shearer Oct 07, 2007
    you will need a VOM (Volt-ohm meter) to verify input voltage
  • joey  shearer
    Yes you have to actually lift the cooktop burners and start to remove the whole control console, the board is axcessed though the rear of the panel. And Its not always very easy to axcess them.
  • joey  shearer
    Yes the part number for the EOC is WB27X5584 and a new black faceplate is WB27X5588 i recommend that as well.
Getting -F3- code when I try to use the oven
This is an Open or Shorted oven temperature sensor.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. Hope this helps...
Jul 23, 2011 | GE JSP69 Electric Kitchen Range
Ge jbp70bk electric range oven and display does not work
HI- Sounds like you need a new Clock/Controller. As long as everything else is working, getting power then it's most likely the controller. The part is about $120. Hope this helps.
Sep 24, 2010 | GE JBP70BK / JBP70WK Electric Kitchen...
GE JBP79 door locked, no led readout after self clean
Hello- Control is about 250$. Could save 100$ by installing yourself, but the popular "self-destruct" cycle can cook other switches and what-not. Find a tech and inquire up-front if completed repairs are too high, they keep parts, you pay trip charge.- Hope this helps- ED
Mar 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
Oven, oven light and oven led display will not work
that sounds like an erc[electronic range control] or clock timer etc. You can check power supply to it but chances are thats what you need.
May 20, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
GE model JKP13GOP2BG control panel faulty ( F1 code)
Often times when someone makes an attempt to "repair" a control, it does not hold up. Replace the entire control. Don't waste your time. You will also get a year warranty on a replacement control.
Dec 13, 2008 | GE JSP69 Electric Kitchen Range
Electronic Display
Go to, for a cheap fix on these displays. It worked on my jenn air.
Oct 29, 2008 | Jenn-Air JES9860 Electric Kitchen Range
GE JSP69 Electric Kitchen Range Logo
365 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
