Question about Husqvarna New Hedgetrimmer 226HD60S
Husqvarna 226hd60 wont rev
Starts fine will not rev past half throttle,low revs a bit slow to respond,definitely running weak
  • 4 Answers
Play minecraft to cheer up
Posted on Nov 16, 2013
I have a crf 450 2008 its not running well at low revs. spluttering, but ok at full revs? any ideas?
Is it modified? Does it sputter only at low throttle or any position of the throttle? Does it start and idle ok?
Mar 04, 2015 | Motorcycles
What is the proper way to adjust the high low carburetor setting on a Poulan Pro weed eater
Both should be set at 1 and a half turns out to start. Turning the screws out will richen. Turning in will lean. If its hard to start or boggs/ dies when you throttle then its lean- turn the low out another half turn. If it revs up for a minute then slows down richen up the high. At full throttle you still want to hear a bit of a cackle- adjust the high
Jul 08, 2014 | Garden
Engine starts and idles fine, but will not rev up (2001 Jeep Grand Cherokee 3.1 diesel auto)
If it was a fuel shortage the engine would rev but to limited speed. This is a lack of air to throttle body. Check for clogged air filter and all the piping and the throttle body.
Sep 28, 2012 | 2001 Jeep Grand Cherokee
93 chevy suburban v-8 tbi hard to start, but starts, will run but will not idle, can keep it running or driving as long as you rev engine constantly. Holding engine at half throttle it will slow and die. ...
Assuming your engine is in good mechanical condition, there are only a few options.
1. You may have a vacuum leak.
2. The pickup in the distributor may be worn to the point that it is sloppy at idle but normal at higher rpm.
3. Idle control valve/motor may not be working properly.
It probably isn't an ignition related problem as the problem would normally get worse as RPM increases. I've seen #2 about 5 times in the past year or 2 so it's not uncommon and would recommend replacing the entire distributor if you come to that conclusion, but would definitely check all vacuum hoses first.
Jun 24, 2011 | 1993 Chevrolet Suburban
Need cold setting for idle mixture screw
unfortunatly with mixture settings its a bit trial and era but the best place to start is turn the mixture screw right in then back out 1 and a half turns run the bike once warm rev on full throttle for a second then let cooldown and check the plug you want a nice tan colour electrode to indicate perfect mixture if plug shows black turn the screw out half a turn more or if the plug starts to white screw in half a turn basicly if rich more turns out if weak more in but just do half turns at a time hope this helps
Oct 27, 2010 | Suzuki GSX 750 F (Katana Motorcycles
Starts,runs but with no power and smoke
my jetta did same thing. it was vaccumm switch on firewall.
Oct 05, 2009 | 2003 Volkswagen Jetta TDI
Fuel Air Adgustments .What they are Set at.& Which are which?
The air looks after itself when you operate he throttle. This how you adjust the fuel....There are two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time. Start with H (high) with the saw at full revs. Turn anti clockwise untill you get max revs then turn it back a little bit. If its running too lean it will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Sep 07, 2009 | Garden
My quad starts fine then cuts out on low revs, it runs perfect with open throttle and also splutters whilst going slow and ides? thanks
mate adjust the mixture screw on the carb to its correct setting in the manual and put the idle screw in a bit so the revs rise a tad good luck
Jul 07, 2009 | 1976 Honda CB 100
Suzuki 2009 DR-Z 250 won't rev past half throttle
I would have it checked out. I know that it has limitors on it but it shouldn't be half throttle. It should rev as soon as you start twisting the trottle.
May 21, 2009 | 2001 Suzuki DR-Z 250
Husqvarna New Hedgetrimmer 226HD60S Logo
150 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
