Question about Dryers
Hotpoint dryer wont heat
My dryer won't heat up model dwl2800dl
    Problem Solver:
  • 11 Answers
Bad heating eliment
Posted on Nov 17, 2013
4 Suggested Answers
  • 139 Answers
SOURCE: no heat
hi there
your problem is either the t-stats have blown which is very common or your heater is blown..
im guessin your t-stats beacuse they are the most common on hotpoint dryers to blow. There always blowing
They located at the back of the dryer behind the protuding panel so there for you dont need to open it all up just that panel.
To check if their blown check for continuity,, no continuity no good merry christmas cheers
Posted on Dec 24, 2007
Jimster
  • 240 Answers
SOURCE: PROBLEM WITH HOTPOINT DRYER
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1811&modelDesc=DRYER&modelNumber=NVLR333ET0WB&documentID=E2136683&documentTypeID=PLDM&documentClassCode=PV&titleType=DRUM%2C%20BLOWER%20%26%20DRIVE%20ASSEMBLY&titleID=00004&
This is a diagram of your particuliar unit. These Hotpoints are manufactured by GE. The heating element is right behind the drum itself. First is to unplug the unit. Open the door, and look at the top edge of the top of the door. You will see two screws that hold the top down. Remove these screws, then lift the top off. You will have to reach your hand under the drum (and really reach around) and unhook the belt from the idler pully and motor pully. The drum is now free to pull out, directly forward. Your heating elements are now right in front of you. Be sure you check both for drooping, touching each other or the sides, broken wires, etc. Also, these elements are very, VERY expensive. They make a rewire kit that will save you a TON of money. Instructions are included with the kit, Be sure when you put the drum back in, you grease the rear bearing slide and plug.
Heater Assembly (whole unit) Part Number WE11X103 $90.00
Restring Kit: WE11X203 Part Number $35.00
Also, both of these parts are usually found on E-Bay in groves. Do yourself a favor, do not buy them from Sears, they have too high a mark-up, shipping is also way to high, and takes forever to get there. Let me know if you need further help. Thanks and good luck!!!!
Posted on Feb 02, 2008
  • 5 Answers
SOURCE: Dryer won t heat 100 74732400 model
dryer element. Common problem easy repair.
Posted on Jun 07, 2009
Electric dryer wont heat
hi 1st check heater for breaks then go for stats
Mar 07, 2013 | Hotpoint Dryers
Hotpoint Dryer model DLL2650BFLWH won't blow heat
So your not getting any heat. There could be a number of different problems. I believe this is a gas dryer. You would need to remove the drum and check the ignitor. This is a little complicated and I would recommend a technician since this is a gas drier.
Oct 27, 2012 | Hotpoint Dryers
My dryer wont come on its a hotpoint model #dlb2650bgl the timer is ticking the interior light comes on my husband put a multi-meter on the start switch and shows power what else could the problem be
The first thing I would check is the door switch. If it isn't closed the dryer should not start - although the timer would be active. If it won't tumble or heat then that is the first thing I would check and on Hotpoint that is a high failure rate.
Dec 31, 2011 | Dryers
My hotpoint dryer will not produce heat any longer. it seemed to be weak at first on heat production taking 2 sometimes 3 cycles to completly dry clothes now its stopped all heat production what would be...
There are two solutions to this problem. The first one is to check your vent hose. It could be plugged up and it won't vent out. Second problem is it your elements. Depending on what model of the dryer the tops of getting it fixed would be $150 with labor.
Apr 21, 2011 | Hotpoint Dryers
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Hotpoint dryer not heating, dryer tumbles but no heat.
check the switch is working then go to the heating coils and check there working ok the next thing to go to is the heat censor inside above the door if this is not working you wont get any heats at all,
Jul 01, 2010 | Hotpoint Dryers
Hotpoint wd420 washer dryer dryer is not heating up
heatman101
Mar 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint ctd 40 wont heat up
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jan 27, 2009 | Hotpoint Dryers
Dryers Logo
53 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
