Trane twg030a140b1 have a bad evaporator, what model can I replace it with
2 Suggested Answers
  • 119 Answers
SOURCE: Determining the age and size
The serial number on that evaporator will have the date code in it, the model will tell the capacity (size). It looks like it is a 4 and a half ton or 54,000 BTU coil and has a TXV valve to meter the refrigerant.
Posted on Jun 17, 2011
Trane 4TEE3F39A1. What is tonnage?
Your Trane air handler is capable of managing evaporative units up to 3 tons.
Mar 06, 2016 | Heating & Cooling
Where do i find the expansion valve on a 3.5 ton trane air handler. Model no of the trane air handler is: 2TEC3F42C1000AA
The TXV (thermostatic expansion valve) is always at the end of the high pressure liquid line as it enters the evaporator. This is the small line. The outlet of the TXV will usually have 4, 6 or 8 smaller lines feeding proportional portions of the evaporator coil. You have to remove the cover of the evaporator to access it.
Some units do not use a TXV, so you may have a 'fixed restrictor' instead. It too is located where above described.
Apr 28, 2015 | Heating & Cooling
How to find the diagram wiring for Trane TWG030A140B1
http://www.trane.com/Commercial/Uploads/Pdf/1111/2_4tec3.pdf
Jun 19, 2014 | American Standard Acont200an11aaa...
Trane twg030a140b1
Do you have the wiring diagram for this unit?
Nov 16, 2013 | Heating & Cooling
Determining the age and size of a Trane evaporator Model # TXH054A4HPAF
Jun 16, 2011 | Ruud UAKA037 Air Conditioner
Trane Air Conditioner air handler drips water
are you still having issues with your twg030a140b1? the heatpump that you own should not be having this issue the question is the configuration of the coil in the AHU is it properly installed. I am a distributor for Trane equipment and am wondering if the install tech installed correctly
May 30, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
Hello i want to conect a trane condensator 2twb0036a1000ba to a trane evaporator mww536k10raa i need a wiring diagram
Your wiring concerns may be more with the thermostat wiring connections than the condensor connections. if you look inside the cover of the evaporator unit (usually called air handler) there should be a wiring diagram glued to the panel cover. This diagram will show all 3 units (stat,cndsr, airhndlr) and the wiring needed between them. Trane and Lennox are notorious for having the most wiring between components. You also need to be sure the stat is the correct type for the system (i assume this is a heat pump system) and there can be as many as 9 wires from stat to system and 6 wires from inside to outside units. Also, the stat will have a wiring diagram with it that shows most typical system wiring including the wiring between in and out units. Your best bet (if you have no diagram on the unit or with the stat) is to call trane and have their tech division fax a diagram to you. Goodluck,Macgivor
Jan 27, 2010 | Heating & Cooling
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
