Question about Ice Cream Makers
Slurpee drink maker instructions - Ice Cream Makers
How many ounces are in 8 cups of water
2 Quarts, 64 ounces
How many ounces make 8 cups of water??!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid=20110510124322AATVk3D
May 10, 2011 - 8 cups is 2 quarts or 64 ounces and no you do not HAVE to drink 2 quarts of water to be healthy. You do have to drink enough to not be ...
How many cups are in 8 ounces of water? - Quora
https://www.quora.com/How-many-cups-are-in-8-ounces-of-water
There are exactly 8 fluid ounces of water in a cup. However, that same water weighs just over 8 ounces avoir du pois. (8.3454) This depends a little on ... how many ounces are in 8 cups of water Google Search
Aug 17, 2017 | Ice Cream Makers
Any maintenance issues on a taylor 430 frozen drink machine
The Taylor 430 is a solid machine. The only maintenance you need to worry about are:
1. Cleaning - Follow the instructions. Supplies are here.
2. Replace wear parts - Scraper Blades and Tune-up kit
The next most purchased part for that machine is the freezer door, but the good news is the new replacement is much stronger than the old ones.
Soft Serve Parts 430
May 12, 2017 | Taylor Ice Cream Makers
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Donvier Ice Cream Maker instruction/recipe booklet needed
Hello! I bought one at the thrift store, and found the instruction booklet here- http://lib.store.yahoo.net/lib/sendicecream/donvier.pdf. Have Fun!
Nov 18, 2009 | Donvier Ice Cream Maker 1 Quart
Magimix Ice cream maker - Le Glacier - lost instruction book
Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support. Manual for ice cream maker ... Need Instructions/User Manual. Magic chef ice maker model MCIM30TW ... fixya.com/support/p519941-magimix_2200_gelato_chef_1_03_quart_ice/rss
best regards mike
Aug 17, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
NO instruction manual
You get the instructions here, they are in three languages, right side is English :
Arctic Twister
Oct 15, 2008 | Rival Ice Cream Makers
Freezer bowl not frozen!
Preparing the Freezer Bowl:
The freezer bowl must be completely frozen before you begin your recipe. The length of time needed to reach the frozen state depends on how cold your freezer is – for best results, place the bowl to the rear of your freezer where it is coldest. In general, freezing time is between 6 hours and 22 hours. To determine whether the bowl is completely frozen, shake it. If you do not hear liquid moving, the cooling liquid is frozen. For the most convenience, leave your freezer bowl in the freezer at all times so you can take it out any time for immediate use.
Features and Benefits:
  • Freezer Bowl – The double insulated freezer bowl contains a cooling liquid between the bowl walls to create fast and even freezing. In general, the required freezing time of the bowl is 6 to 22 hours before use. Additional freezer bowls are available separately for making double batches or different flavors without interruption. For additional information on preparing the freezer bowl for use, please see below.
  • Base and Motor Unit – The base contains a heavy-duty motor that is strong enough to handle everything from thick, rich ice creams to smooth frozen yogurts to slushy frozen drinks . The base unit features a generously sized on/off switch, rubber feet to prevent slipping and keep the unit stationary while in use as well as cord storage to keep counters neat and safe when the unit is not is use.
  • Lid with Ingredient Spout – The easy-lock, transparent lid secures to the base with a simple turn, allowing you to watch the freezing process as it progresses. An ingredient spout at the top of the lid is generously sized for pouring in ingredients and ideal for adding nuts, fresh fruit, candy pieces and more without interruption the freezing cycle.
  • Mixing Arm – The mixing arm mixes and aerates your frozen desserts and drinks, incorporating and blending all ingredients thoroughly.
  • Instruction/Recipe Book - The included instruction and recipe booklet helps you get started with over 30 recipes and variations for ice creams, sherbets, sorbets, frozen yogurts and frozen drinks.
  • Feb 29, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
    Need replacement parts
    Unfortunately, Nostalgia Electrics has stopped (AGAIN!) production of the ICM-517 and ICM 562 Soft Serve Ice Cream Makers. And the company customer service is a "bear" to get a call back from. You could go to the Helman Group, LTD website or the Nostalgia Electrics website and click on customer service and type in your request, but don't expect a quick answer. And there is an 800 # to call also, but you will only get the voice mail and leave a message. No live person, just a call back, if you're really really good and really lucky. It's a shame they have so much trouble with these, they seem to do well with the Popcorn machines, cotton candy, and drink machines, hot dogger, ect. You'd think they could debug this one too. Kindest regards, Joe.
    Feb 09, 2008 | Nostalgia Electrics ICM-507 Old Fashioned...
    Ice Cream Makers Logo
    23 people viewed this question
    Top Ice Cream Makers Experts
    Andrew Taylor
    Andrew Taylor
    Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
