Question about KitchenAid KEBC147 Electric Oven
F6 error displayed - KitchenAid KEBC147 Electric Oven
Error code F6E0 on Kitchenaid KGSS907000 wondering if it is the control board or touch screen, what other components could cause this?
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control board
May 02, 2014 | KitchenAid Architect Series KEBC107KSS...
F6 E6 error code?
This fault is a communication error at the appliance manager, could be a loose wire or a bad display transformer, either way you will need a certified technician to fix this issue, there is no simple plug and go issue to resolve. I personally found the problem to be the transformer not send voltage to the appliance manager. This is solvable but needs someone who understand electronics to correct this issue.
F6 E0 Oven user interface - lost communication E6 Oven appliance manager 1 (upper, single) - lost communication
This is directly from the tech sheet of your oven and directly from the factory web site.
Good Luck
Dec 03, 2013 | KitchenAid KEBS179B 27" Built-in Electric...
Display f6 display f6
Hello, Thank You for using FixYa. I will be helping you today.This is a oven sensor error.The part number is W10131825 Its in the top right corner of the oven two screws hold it in.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | KitchenAid Architect® KEMS308SSS Stainless...
Error code f6eo
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control.
Apr 25, 2011 | KitchenAid Architect® KEMS308SSS Stainless...
Error code f6eo
Dec 26, 2010 | KitchenAid KEBC147 Electric Oven
ERROR CODE F6
F6 error code relates to the power board excessive temperature,this points to the cooling fan situated on top of the oven unit being faulty.
You already said it was noisy which is most certainly coo;ing fan.
Hope this helps.
Apr 16, 2010 | AEG CB8920-1-M Electric Single Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Microwave display just flashed F6 error code. Only mention in manual is for lower oven display.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and remind us that it displayed an F6 error code.
Nov 26, 2009 | GE JKP85 Electric Double Oven
Shuts off when preheating with F3 or F6 error
The F3 error on this model is an open thermostat circuit. The F6 is a control or loss of power. Make sure the unit is plugged into a good 120 Volt outlet. Test this outlet with a power drill or lamp, wiggle cord in receptacle, if no other test experience or equipment is avaliable. Check the thermostate in the oven for physical damage. There may be a loose connection in the oven. This would require a good technican to find.
InMrFixIt
Feb 20, 2009 | Kenmore 33169 Gas Single Oven
KitchenAid KEBC147 Electric Oven Logo
11 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
