I have been unsuccessful to get the HDMI ports on the 4806 to work. I've tried numerous things based on previous posts but no luck. I run a HDMI cable from the DVD player to the 4806 and then an HDMI cable from the 4806 to an epson 8100 projector. I've tested the cable by connecting the DVD player with the cable that runs to the projector and its displays fine. I've set the video single on the DVD player to 480i (along with all the other settings, Auto, 720, 1080, etc) and still nothing. All these signals work directly on the cable up to the projector. I've also tested the input cable (connecting the DVD player to another HD TV). The Video inputs are set to DVD player in HDMI 1 (I've tried the other two inputs and no luck). I"ve turned the HDMI Output convert to on and still nothing. The component video for the DVD player works without issue. Could the HDMI ports be bad having never used them? Denon site says there is no update for my model or serial number.
SOURCE: Setting Up New Denon AVR-588 / Adding Sony DVD with Component Video cables
Make sure you have receiver switched to proper input as coax rather than digital
SOURCE: HDMI output from AVR-4806
You say your connected from the DVD to the Denon with an HDMI cord and the Denon to the TV with an HDMI cord and you get no DVD video? can you get the Denon setup menu? if so change the res. output on the DVD to 480p, 720p or 1080i but not 1080p
SOURCE: Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Testimonial: "Thanks. Very helpful"
