Question about Ovens
Whirlpool akz161 top oven. The lower heat element is not working how do l access this as l need to fix it myself
The top oven has heat at the top but there is no heat at the bottom. The bottom oven works ok, last month had to change the element
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Open door if you can see screws at element ends remove them and change or you will have to do it from the rear
Posted on Nov 22, 2013
catriver
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
SOURCE: Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Posted on Jan 06, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 13 Answers
    SOURCE: Neff U1721 bottom oven not heating fan & light are ok
    Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
    Posted on Jul 29, 2009
    barkencoa
    • 3463 Answers
    SOURCE: I have a Whirlpool AKZ161/ix/03 double oven in
    If it is fan assisted, and the fan is working o/k, then the chances are it is the element.
    This is usually located at the rear of the oven compartment behind a removeable cover.
    Normally a straightforward repair
    MAKE SURE POWER IS OFF !!!!
    Please rate my solution.
    Thankyou.
    Posted on Jan 27, 2010
    Whirlpool gold double oven model #gbd307pdb. upper oven lower heating element burned out. replace lower element. it does not get hot. upper element heats up. control board works. is this the thermos
    You will have to see if there is power to the element. It is possible that the relay contacts burned when the element burned out. There is a fusable link but this would shut down both the top and bottom elements. If the relay is burned out the control board will need replacing or rebuilding.
    Oct 28, 2014 | Ovens
    Whirlpool gbd307 why will The upper oven not work but the lower oven works
    Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
    Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
    Top oven does not heat-although bottom oven is ok.
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Jul 29, 2010 | Whirlpool GBD277PD Electric Double Oven
    The oven does'nt seem to be able to heat up above 150, the fan is working, the bottem half of the oven does'nt seem to heating up. Is this fixable or do i need a new oven?
    Hi.
    If the part that is not heating is only the bottom element, and the top element is heating regularly, then you may need to replace the lower element.
    Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
    If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
    Regards.
    Mar 04, 2010 | Whirlpool RBS275PD Electric Single Oven
    I have a Whirlpool AKZ161/ix/03 double oven in which the bottom oven will no longer heat up to the required temp. I suggest it is the heating element. As a novice will I be able to change the element and...
    Thankyou.
    Jan 27, 2010 | Ovens
    Ihave a whirlpool oven model gbs277pdo1 that will
    this could be the timer is set to auto this data sheet might help For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
    To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
    2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
    3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
    4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
    Jan 13, 2010 | Whirlpool GBS277PD Electric Single Oven
    I ran a cleaning cycle on the lower oven. Now it won't heat
    the answer is the thermal sensor, mine has gone bad everytime I clean the oven. Solution, run a fan on the oven while you are self cleaning, this keeps the outside heat away from the unit. Pain to replace the sensor, its in the middle back of the oven, have to pull the whole unit out.
    Sep 24, 2009 | Whirlpool RBD306PD Electric Double Oven
    Older Whirlpool RB170PBX both ovens out
    these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
    Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
    Ovens Logo
    109 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
