Question about Health & Beauty
Lumiscope 1085m the plastic connector between the cuff and the monitor broke. How can I fix it or get another one?
Error 3 is showing on my monitor ... What does it mean ?
On other blood pressure monitors from Life Source, the error 3 means that the blood pressure cuff isn't inflating properly. The cuff could be incorrectly fastened or the air connector is backwards or not connected to the cuff or the monitor. Check this on your monitor.
I hope this helps.
Jul 08, 2014 | Health & Beauty
Lumiscope Model #1090 will no work
check the cuff for air leaking and the conectors
Feb 18, 2014 | Lumiscope Health & Beauty
How to reset time and date on omron - 742 b/p unit ?
I need instructions for using Lumiscope Blood Pressure monitor Model 1094
Feb 06, 2014 | Omron HEM 780 Automatic Blood Pressure...
Err code 3
From manual at pag.3:
err code 3Appears when pressure value did not increase during cuff inflation: 1) cuff is not fastened 2) air connector is not connected properlMake sure cuff tube is properly connected to monitor, cuff is securely fastened and exhaust rate is between 2 mmHg and 5 mmHg. Make sure air connector is inserted properly into tube and monitor.
refer to manual
Mar 05, 2012 | Lifesource UA 767 Plus Digital Blood...
I dropped my Luminscope aand now it seems to read about 10 points to high. I cannot find manual . to see if there is a way to calibrate it.
Recalibration, normally has to be performed by the manufacturer. They can not be re-calibrated in the home.
Apr 16, 2011 | Lumiscope Semi-Automatic Cuff...
Lumiscope 1060 lost my manual, when do you stop inflating and read your pressure ?
Using a stethoscope over the place you can feel a pulse in the crease of the inner elbow, pump up the cuff until you no longer hear the pulse beat. Let the air out slowly until you hear a pulse, that is the systolic (top) number. Continue to let the air out until you no longer hear the pulse - that is the diastolic (bottom) number.
Congratulations on taking an active role in your health!
Dec 01, 2010 | Lumiscope Professional Blood Pressure Kit...
I have a Lumiscope Digitronic model 1085M. The
I just Rec'd a model # 1133 this A.m. I went to take my Husbands's bllod presure and it the ERr kept coming up so I plugged it into the electric socket I just hope that is all it is and were do I go to register this blood presure mesaurer for the wranty
Jun 03, 2010 | Lumiscope 1080 Deluxe Auto Blood Pressure...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
