Question about Garmin GPSMAP 3205 GPS Receiver
Light on screen low can not see in day light.
Why won't my low coolant light go off?
Not sure what year Elantra you have but most don't have a low coolant light. If you do have one, check for a faulty level sensor.
Dec 29, 2017 | Hyundai Cars & Trucks
Alcatel one touch sonic wont turn on....
return to seller would be my option
Dec 26, 2014 | Alcatel Cell Phones
Screen is in night mode how to get back to day mode
Your unit is probably set up to change to night colors when the lighting outside is low. It should go back to day colors when more light reaches the GPS.
If you still want to change it, tap on the screen, tap on the preferences icon, then tap on the right arrow until you see an icon laebled "USE DAY COLORS". Tap on it and you'll have your day colors back.
Apr 01, 2010 | Tomtom ONE GPS Receiver
Hi I have a 1997 for f150 I have no high or low head lights
check the fuses first, no luck replace the day time running light module.
Jan 27, 2010 | 1997 Ford F150 Regular Cab
Low coolant light
change sensor in water tank
Aug 13, 2009 | 2001 Pontiac Grand Prix
Day time running lights don't work dashlite indicates they are on
Probably daytime running light module needs replace. They should be able to test that at repair shop to confirm before replacing.
Jul 22, 2009 | 1997 Chevrolet Tahoe
LG Viewty - negative screen
Maybe the back light is set to low or the LCD screen is set to low
check the phone settings ...
May 28, 2009 | LG KU990 Viewty
Low light wont turn off!!!
number1 be sure that you,re using energizer lithium batteries only.they,re the best.2 because these cameras have such a small flash and its placed in the front of the camera instead of the top,they,re not really made for night shots.but from 3-5ft you should get great pics at very low light.just put it on auto,and ignore the low light message,press down and hold for 2seconds then release.you should get great pictures this way.good luck,hope i helped
Apr 29, 2009 | Samsung S860 Digital Camera
White screen in sun light
your lens ( iris may be sticking ) and its cables need cleaning : an authorized service center will replace the lens - possibly under warranty , if you call sharp customer service with sales date information , first ;
Aug 19, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
M515 green light on and dead screen
Hey, i had the same problem. My m515 stayed with the green light on for 3 days until the battery died out (and lost all my data). I keep the m515 off and without recharge for 2 more days. Then I recharge it in its craddle and it seems to be ok. Good luck
Sep 19, 2005 | Palm m515 Handheld
Garmin GPSMAP 3205 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
