Question about Empire BT 4 Slice G36 Elite Paintball Marker
G36 paintball marker keep firing
Single shot no problem,but pulling trigger fast starts shooting till all air is finished
My Tac-5 Recon marker does not shoot the paintballs. I cock the marker and after I pull the trigger I can feel and hear the spring action but no paintballs are launched. When I attached the CO2 tank I did...
take the hammer and bolt out, clean them and oil them with paintball oil (no motor oil or WD-40)
air tool oil also works, but besides paintball and air tool oil, never use anything else.
the bolt is in the front of the marker, it is what pushes the paintball from the breach into the barrel. the hammer will be towards the back. its been years since i have touched a tac-5
easiest way to oil is just to put a few drops in the asa (where you attach the tank) and dry fire with the barrel off a dozen times. this will get the oil everywhere it needs to be.
if you can take it apart and clean it i would still recommend that
Jan 05, 2018 | Tippmann A 5 Standard Paintball Gun
The paintballs just fall straigt out of the gun or shots like 5 at a time
The part that is bad Tippmann calls a "ball latch". It's a small orange rubber part that keeps the ball in place before the marker is fired. The parts is inexpensive it is common in most paintball stores or can be found online at www.tippmannparts.com
I highly recommend taking this paintball marker to a local pro shop to have the part replaced. You can service this marker at home but is not easy to put together if you have experience working on then, they have a few springs under tention that make it tough to put back together. If you are interested in doing the repair yourself I highly recommend doing it on on a clean floor in a clean room so when you disassemble it it will be easier to find the springs that could shoot out.
One thing that will make it easier is to leave the feedneck on. It will keep one less spring from jumping out at you, just a tip from a pro. I also highly recommend not using a spray lubricant and to only use oils in you tippmann made for paintball guns.
Sep 19, 2011 | Tippmann 98 Custom Act Paintball Gun
When i put my paintballs in the gun and i aim down they fall out the top where they shoot from
Sound like your ball detent is gone or broken.
The detent is a tiny piece of rubber that keeps the paintballs in the chamber and from rolling out the barrel. It's a cheap part, but you will need basic knowledge of disassembling a Tippmann 98 to replace it.
You can find ball detents here!
Feb 12, 2011 | Tippmann 98 Custom Act Paintball Gun
My gun wont shoot. Ill **** it once and it will fire a dead shot then not recock
Time to lube (oil) the gun. A few drops of oil in the inlet hole (where you screw on your tank) should do and then dry fire the gun. If no luck you may need to tear down the gun and clean and lube the internals.
Here is your manual.
http://www.paintballadvisor.com/manuals/Tippmann%2098c%20manual.pdf
Oct 06, 2010 | Tippmann 98 Custom Act Paintball Gun
I have an a5 paintball gun with electronic trigger, when i hook it to air and pull the trigger, the hopper is not moving!!!
On the A5 the hopper or Cyclone feed is powered thru a small tube on the feeder side
of the gun. Make sure that tube is connected and if so, pull it off and see if air is flowing
thru it when you pull the trigger. If not, the internal passage may be blocked. Tear down
the gun and clean out the obstruction. If there is a pulse of air coming out the tube when firing
then it may be the Cyclone feed mechanism. Just unscrew the 3 phillips head bolts
under the Cyclone and observe the air driven gear drive. Air up the marker and see
what is moving or not moving. Complete replacement upgrade Cyclone gear drives
are available that say they increase performance if you cant get it moving.
Here is your manual
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Sep 25, 2010 | Tippmann A 5 Standard Paintball Gun
Squeeze trigger once and it fires 3x
if there is a 9 volt battery in the handle, there should be 3 to 5 small dip switchesright by the battery, your set on 3 shot burst, unhook the gas, turn all switches off, and test it, there is also a full auto setting, try different combinations untill you get single shot
Sep 15, 2010 | Tippmann 98 Custom Act Paintball Gun
My gun just beeps when i pull the trigger even when hooked up to hpa.battery is new.last time i used the gun just before it messed up i had it hooked to o2 and it would fire then beep ,i have a anti syphon...
You have probably messed up your solenoid, did you fire the marker straight up with the o2? I would make sure that all of the board settings are back to factory default especially the dwell and reattempt with compressed air. If the marker is still not firing get your hands on a new solenoid for it.
Sep 09, 2010 | Smart Parts Shocker NXT Paintball Gun
My A5 just rapid fires when the trigger is pulled even in semi, if you release the trigger it stops but does it everytime I pull the trigger and the E-trigger seems to be working fine
Make sure your battery is new. It doesn't take a lot of voltage drop to affect performance.
Make sure your marker is clean, and properly lubed with a quality oil make for paintball.
Make sure your board connections are secure. You can change modes on the e-trigger yes? Go through them and fire a few times in each to ensure it's changing.
Make sure you have a full tank of air while your testing to make sure this isn't a problem as well, or causing your issues.
Play hard, play safe, play with honor!
8^)
Aug 02, 2010 | Tippmann A 5 Standard Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Empire BT 4 Slice G36 Elite Paintball Marker Logo
75 people viewed this question
Top Empire BT Sport & Outdoor - Others Experts
Bill Eager
Are you an Empire BT Sport and Outdoor - Other Expert? Answer questions, earn points and help others
