Replace both fuel tank level sensors and now this code
SOURCE: HOW TO YOU GET AT PRESSURE SENSOR ON COMMON RAIL HYUNDAI SANTA FE 2007 CDX
This is what it looks like
SOURCE: ''check engine light'' illuminated, 1004 Hyundai, Santa Fe
If you live in the US, take it to qany Auto Zone store and thy will read the codes off for you, I would suspect any right thinking competitor would do the same, check if you don't have one near by.
Hope this is of some help.
Ed
SOURCE: Unable to fill the gas tank when the car is sitting level
These fuel tanks are designed weird, they have a hump in the middle for the driveshaft. Most of the time I have found if the pump clicks off early it is the fuel vent valve, which is located on the rh side, but a fuel cut valve could do the same thing. If the pump clicks off early (sometimes after 1 gal), make sure the canister filter isn't clogged and replaced the vent valve.
SOURCE: PROGRAM KEYFOB FOR HYUNDAI SANTA FE
This is from the factory service manual of your car:
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Translation you need the dealer to do this.
SOURCE: 2002 hyundai santa fe front transmission leak
swap w/rear radiator rear doesn't require fluid.
