Question about Toshiba M782 VHS VCR
Where can I buy square drive belts? - Toshiba M782 VHS VCR
    Champion:
  • 236 Answers
Changing serpentine belt on 2004 dodge ram 1500
Should be a diagram on hood.or at radiator .
May 30, 2014 | Cars & Trucks
Belt tensioner is very noisy, I need to know how to replace it ?
this is a fairly straight forward repair. diagram the routing of the belt, remove the belt, i believe the tensioner has a square 3/8 drive hole you can put a ratchet in to unload it. then unbolt the tensioner. i wound also recommend replacing the idler pulley at this time. you will need to know if the pulleys on your engine are smooth or grooved when buying the parts
Apr 02, 2014 | 2000 Lincoln Continental
Where do i buy drive belt FOR SONY CASSETTE DECK TC-K8B
Any spares shop can make a match but otherwise this is for the round or square belts only You can fit a round belt in place of the square type it does not matter. I had some reel to reel machines and in desperation I went to a Hydraulic cylinder and pump spares shop and got an "o" ring of the correct length and thickness Remember that the new belt must be SLIGHTLY shorter to give grip on the pulleys. I have several units cassette and open reel that I was forced to fit this type and some some are running now over ten years everyday
May 02, 2013 | Audio Players & Recorders
Replace serpentine belt
super easy use a 1/2 inch drive breaker bar insert into tensioner pulley where there is a square hole, push until tension makes belt slack and be sure to remember how it comes off for easy install of new belt. Buy a good high quality belt too.
Mar 09, 2013 | 1998 Ford Crown Victoria
The instructions I have for insalling the tensioner say "The tensioners are equipped with a square hole on the tensioner to rotate the tensioner arm for installation. A 1/2" socket driver wrench...
Yes, you use a long 1/2" ratchet or breaker bar
in the 1/2" square hole to release the belt tension
Don't need torque specs
I doubt you even own a torque wrench
Apr 01, 2011 | 1997 Dodge Dakota
Need to replace belt. Is there only one belt on the engine?
Yes only one the serpentine belt. If you are a good drawer jot down the exact way your belt is on your van and replace it the same way. There is a square hole on the belt tensioner you use a 3/8" or 1/2" drive into it to release the tension. Best thing is buy a Haynes repair manual from the same autoparts store you are buying your belt and read up on how to do this procedure.
Good luck and thanks for your question and I hope my suggestions help. burdfrenzy
Visit My eBay Store!
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 24, 2010 | 2000 Dodge Caravan
I need to replace my serpateen belt how do i do that?
This label shows the accessory belt routing on a Lumina with a 3.1L engine
  1. Disconnect the negative battery cable.
  2. Remove the drive belt shield.
  3. Fit a 3/8 inch breaker bar or ratchet to the square hole in the tensioner. Lift, or rotate the tensioner off of the drive belt. When the tension on the belt is removed, slide the drive belt from the pulleys.
To install:
  1. Taking care to follow the proper routing of the belt, slip the belt onto the pulleys. As a help, note that the water pump pulley is usually driven from the back (smooth side) of the belt.
  2. Fit a 3/8 -inch breaker bar or ratchet to the square hole in the tensioner. Lift, or rotate the tensioner and, with the belt in place, gently release the tensioner.
  3. Verify that the belt is correctly routed and aligned in the proper grooves of the accessory drive belt pulleys. Inspect the drive belt length scale on the drive belt tensioner for the proper indicated length. If the drive belt length scale does not indicate the proper installed length, the belt may be incorrect, incorrectly installed, worn out or the tensioner may be defective.
  4. Connect the negative battery cable. Start the vehicle and verify correct operation.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 58; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Dec 09, 2010 | 1997 Chevrolet Lumina
How do i get to the serpentine tensioner pully?
If you are trying to replace the belt, then I recommend you go buy a serpentine belt tool kit. Gearwrench makes a nice kit. It comes with most everything you need to take the tension off the belt so you can remove it. You will use the socket that fits the bolt in the middle of the pulley or there will be square notched section where a like a 1/2" or 3/8" drive wratchet would fit.
Dec 09, 2010 | 2005 Chevrolet Tahoe
Change a serpentine belt on a 97 lincoln
3.8L Engine
  1. Insert a 1/2 inch flex handle in the square hole in the tensioner. The tensioner has a square hole cast into the rear of the tensioner body directly behind the pulley. Rotate the tensioner clockwise and remove the belt from the pulleys.
NOTE As an alternate method, a 16mm socket can be placed on the tensioner pulley bolt and rotated clockwise to remove the belt.
To install:
  1. Following the schematic on the decal under the hood, loop the drive belt over all the pulleys except the alternator pulley.
  2. With the belt installed properly on all except the alternator pulley, rotate the tensioner as described above and install the belt on the alternator pulley. Ensure that all the V-grooves make proper contact with the pulleys.
4.6L Engine
WARNING Do not allow the drive belt tensioner to snap back as damage to the drive belt tensioner or personal injury could result.
  1. Rotate the drive belt tensioner clockwise with a breaker bar installed in the 3/8 inch square hole in the drive belt tensioner.
  2. Lift the drive belt over the idler pulley flange and remove the drive belt.
To install:
  1. Following the schematic on the decal under the hood, position the belt over the pulleys, except the idler pulley.
  2. Rotate the tensioner as described above and install the belt on the idler. Ensure that all the V-grooves make proper contact with the pulleys.
Apr 23, 2010 | 1997 Lincoln Continental
How do I release the belt tension pully to replace serpentine belt
You can run down to your local auto parts store and buy a serp belt tool. Or you can take a 3/8 drive ratchet, locate the 3/8 square hole in your tensioner and put the ratchet in the hole. For more leverage I put a deep socket over the ratchet handle and put a long 3/8 extention in the deep socket. This will provide ample leverage and will save buying more tools you do not need. Simply move the tensioner to the direction that takes pressure off of the belt.
May 24, 2009 | 2003 Chevrolet Cavalier
Toshiba M782 VHS VCR Logo
55 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
