Question about Coleman White Rodgers Furnace Gas Valve S1-02543267000
Gas valve won't turn on
We had the model 36C03 running, and we adjusted the regulator to increase the flow, and cycled the valve, and then it stopped working. We tried putting it back to the original settings, and cycling the power multiple times, but it still doesn't work. Any suggestions?
    New Friend:
  • 4 Answers
Have you tested for power at the gas valve or transformer
Posted on Nov 20, 2013
3 Suggested Answers
  • 121 Answers
SOURCE: coleman rv a/c
It is definitely with the compressor. It should more like you may have a weak winding in the compressor, you can a hard start capacitor (sp5 ) that will help the compressor on restart. Note that this is a last chance solution for a compressor.
Posted on Oct 01, 2008
mc1bean
  • 3053 Answers
SOURCE: I have a coleman furnace,
Hello, I read your problem and I believe both problems are related, but good news is I believe a pretty low cost fix and pretty simple solution. Sense your unit is 15 years old, I believe your gas valve is waring out. the reason is it shutting down is your gas valve is not functioning correct which is throwing off your thermostat. Yes it is possible this is a combination of bad thermostat, but i would first replace valve then next thermostat. You might think it is igniter, because it will start on second try, but I believe reason it is starting on second try is gas valve is not opening fully, like slow to open as it is hanging up or just plain wore out. Thanks mike.
Posted on Sep 03, 2011
What regulator does a empire model 115 15000 btu take?
The regulator on the heater probably is not but is probably a device to prevent the heater being used unless the gas pressure is high enough and also serves to prevent air entering the gas line and also serves to arrest flashbacks.
The standard propane low pressure regulator is 14" water gauge but the heater might need a high pressure regulator. The best way to decide which type of high pressure regulator to use, because there are several, is to use an adjustable regulator.
After installing the adjustable regulator the pressure is increased until gas can be heard to be flowing and the heater lit. The regulator should then be adjusted to produce a clean flame of the correct length and then the regulator adjustment locknut should be tightened.
If the heater is to be used indoors it is important to ensure there is plenty of ventilation and the emissions are checked by a gas engineer.
Sep 06, 2017 | Empire Heating & Cooling
Rv heater keeps running
Try cycling your disconnects a few times. Turn off the propane at the tank. Turn on the vent fan. Then turn on the furnace. Yes' I said turn off the gas and turn on the furnace. As the furnace tries to ignite "you will hear the spark" SLOWLY open the gas valve. I say slowly because the tank valve has a safety feature that stops the flow of gas if it is going to fast. By opening the valve slowly the gas will pressurize the line and the valve will stay open.
Here is the reasoning behind this. If your refrigerator, water heater or anything else gas was turned on while the gas valve was off the pressure left the line. When you turned the gas back on there was a rush that let the over sensitive safety valve kick out.
Some models have an electric safety valve connected after the regulator and it is controlled by the gas leak detector. If that detector is set off by anything..hairspray, Frebreeze, bug spray, silicone spray etc... it will turn off the gas at that electric solenoid. Clear the offending spray and reset the detector.
Apr 13, 2012 | Heating & Cooling
Gas valve buzzing
gas regulator mate,between the supply and the appliance
Dec 23, 2011 | Whirlpool Dryers
My Uniflame grill may have a clog somewhere through the fuel delivery system, or at the the tank connection, how would I be able to find the culprit?
Hi boltbucrayfa...
I think your culprit is the gas regulator valve...
If it is not working properly then it will not deliver the proper amount of gas to the burners.
Check all your burners to make sure they are not plugged...
The when you are outside away from Flames and ignition sources.
Remove the hose from the grill...open the gas to the grill (you have the hose off the grill) and listen to the flow of gas...if it is very low then there is your problem.
You can shut off the flow of gas, then tap the gas regulator on the sides, top and bottom lightly with a hammer and then turn back on the gas to see if the gas flow increased...if it did, then shut off the gas and rehook up the gas line to the grill..and your good to go grilling again.
Some gas regulators have an adjustment under the removable cap.
If the gas flow did not increase, the replace the gas regulator
Please take time to rate me
Sep 26, 2011 | Uniflame FG2204C Grill
Kenmore lp gas sealed burner stove,when opening or closing the oven door the top burners decrease in flame size and go out frequently.
This seems like a pressure regulator / flow problem. If you are running more than one appliance from bottled gas this can occurr if the supply pipe is not of sufficient size. When 'wafting the door' you are increasing air flow to the oven burners which in turn will consume more gas to balance the burn, this starves other burners that are running at the time.
Cure; increase regulator pressure (remove the foil cover to expose the screw) with the top burners alight adjust the screw 1/4 turn at a time until the flames are bright blue at heart and organge tipped. Increase as much as you can without the falme distorting away from blue/orange. If this doesn't cure it you may need to increase the size of your supply pipe to 15mm so that the volume of gas is greater and then split it off to normal lpg pipe to each apliance thereby creating a more even flow of supply. Often a system using say heating and gas fire is perfectly fine but add another appliance like a cooker or change your cooker to one which has more powerful burners and you can expose weaknesses in the flow system.
Jan 15, 2011 | Kenmore Kitchen Ranges
How do you adjust the pressure on a watts regulator to increase the flow of water?
Turn it clockwise to increase pressure on a watt's pressure relief valve. You will have to gradually adjust and check pressure till you get it to desired pressure. You don't want to exceed safe pressure due to damaging water lines or fixtures.
Jun 14, 2010 | Watts Regulator Temperature and Pressure...
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
I have a 1987 Goodman, (GU150-5 REV S) model gas furnace. The problem I have is keeping the pilot light on. I replace the thermal coupling twice, work for a few days and goes out again. Please tell me what...
If you have a weak pilot flame it could cause this. There is an adjustment screw for the pilot flame under another philips head screw that takes a small flat head screwdriver to adjust. Turning the pilot flame up may help.
Dec 21, 2009 | Goodman GMS90703BXA Heater
Regulator doesn't allow gas to flow to grill . Grill cannot heat hot enough to grill steaks. Gas flows too slowly.
Shut off the gas at the tank and disconnect everything.
Unscrew the plastic cap on the regulator. Inside is a flat screw top that has a single slot or an X-shaped slot. This is the pressure adjustment. It controls the diaphragm that regulates gas flow.
Note where it's set. Use a Sharpie to mark the adjuster on its edge (place a dot there), and make a corresponding mark on the threads next to it.
Next, use a large screwdriver or a coin to spin the adjuster counterclockwise three or four times. Pay attention to the number of turns. Now, screw it back in (clockwise) the exact same number of turns, stopping at the index mark you made.
Next, turn the adjuster two turns clockwise, followed by two turns counterclockwise. The idea is to end up where it was originally set. This action unsticks the regulator's valve seat. Done.
Put the cap back on, hook it all up, open the tank valve, and make fire.
Oongawa!
-Peegoo
Jun 23, 2009 | Thermos Stainless Steel Gas Grill
Our Bosch 16H Hydropower shuts off 30 secs to a minute after heating has started. We have used a variety of settings and only when we have the lower dial on minimum (fully anticlock) and the slider above...
Hi John
The manual is very limited in information it said to check there is
  • high water flow going through your system
  • and check your gas settings is correct!
  • The slide adjustment is your gas flow, which regulates your temperature
  • I have also increase the the gas regulator, which increases the gas flow
I have also been told its not a good idea to have a water saving head on your shower as this restrict the water out put.
Jul 03, 2008 | Heating & Cooling
Coleman White Rodgers Furnace Gas Valve S1-02543267000 Logo
101 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
