Question about Echo Gas Blower 185 MPH 900 CFM Blower PB620ST
What is the gas oil mixture? - Echo Gas Blower 185 MPH 900 CFM Blower PB620ST
    Sergeant:
  • 417 Answers
Figure out the size if your refueling gas tank, then get the oil that matches the size in gallons. The ratio is a standard 50:1 now for everything
Posted on Nov 21, 2013
I added 0.4 oz of oil to 1/2 gallon of gas too much to mixture. How can I dilute the mixture without starting over?
??? Take a gallon gas can, pour the I/2 gallon oil/gas mixture into it and then add the correct amount of undiluted gasoline to the correct mixture. For instance, if you need a .2 oz/I/2 gal ratio then add 1/2 gal gas to what you already have. Remember, it is always better to have a little too much oil than gas.
Jul 30, 2014 | Husqvarna Weed Eater 26 In Deck 190 CC...
Need gas and oil mixture ratio
The gas oil ratio on all Poulan models is 40:1.
First, I recommend a synthetic oil mix if you can find it and also recommend running a 93 octane gasoline.
Second, I would mix no more than 1 gallon at a time, unless you are doing a lot of cutting.
Gas/Oil mixtures do not last that long. I don't give them more than a month, and generally try to run any mixture within 2 weeks.
Think about it, gas cam gum up on it's own when let sitting for too long. Imagine what it can do with oil mixed in it.
Good luck with your saw, and be careful when cutting.
Jul 07, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
49 CC STREET SCOOTER TWO STROKE NEED THE GAS TO OIL MIXTURE
the mixture ratio is 50 parts gas to 1 part oil. Use only a good quailty stroke oil, never use motor oil
Nov 01, 2011 | Quad 47 cc / 49 cc Pocket Mini Bike...
Need to know the gas and oil mixture for a Homelite 2 cycle weed wacker
Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
May 22, 2011 | Homelite Garden
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Apr 10, 2010 | Ryobi 15" Electric Factory Reconditioned...
Gas/ oil mixture
If it is a riding lawn mower it is probably not a two cycle engine so there would not be a gas oil mixture. It must be a 5 horse power or higher so it would use straight gas. I hope this will help you. donnyb60
Mar 20, 2009 | Poulan Garden
Fuel/oil mixture
3.2 oz oil in one US gallon yields 40:1 mixture.
2.6 oz oil in one US gallon yields 50:1 mixture.
Jan 15, 2009 | Humminbird 140c Fishin' Buddy
Echo Gas Blower 185 MPH 900 CFM Blower PB620ST Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
