Question about Coleman White Rodgers Furnace Gas Valve S1-02543267000
Gas vale not working
We adjusted he regulator, and now it won't turn on the burner. We cycled the valve like the directions told us, but it still doesn't work. Any suggestions?
    Master:
  • 613 Answers
Before the gas valve is energized, the inducer draft motor has to develop enough negative pressure to close the pressure switch and the pilot has to be proven first before the gas valve can be energized. This is dangerous stuff, not dyi, call a qualified tech.
Posted on Dec 08, 2013
2 Suggested Answers
SOURCE: Gas valve won't turn on
Have you tested for power at the gas valve or transformer
Posted on Nov 20, 2013
Gas grill was washed now it won't light
Regulator. Tanks were non burped... Regulator stuck. Turn off tank slow. disconnect. Turn burners on. Tap the regulator with a piece of metal. Turn burners off. Connect tank. Since it was washed out electric starter dont work. Turn burners on. Then you will hear it. Gas. Take lighter and start. Big startup. The hair on your hand burned off wash your hands. Then get the meats! Easy as Cake
Jul 13, 2012 | Grilling
Model #14116670 bq grill low (and sometimes no flame).Sometimes 2 out 4 burners work well
The problem you're having is the result of the OPD (Overfill Protection Device) Vale in the grill tank.
This occurs when the gas tank valve is opened to fast. Or the tank is low on gas.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the exact same way. Do all the burner flames look correct? If so, you
solved the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Aug 22, 2011 | DCS BGB30-BQR Grill
I have a Thane Q BBQ Grill and don't have a manuel and all the posts say to go to a web site but still not able to get a manuel. It has tank of gas The striker strikes but will not light. Any solution....
This is a solution to the same problem for full size LP gas grills, but it will work for your grill, too. Assuming there is gas in the cylinder (?).
Turn the gas valve OFF and remove the cylinder. Wait 10 minutes and reinstall the gas cylinder.
Ope the gas valve VERY, VERY SLOWLY (Slow motion, slow). Once te vales is fully open turn the valve back 1/4 turn. Now, light the burner and turn it to HIGH. Did the burner light and does the flame height look correct? If so, you solve the problem.
If the above didn't work, either the cylinder of gas is empty or the regulator on the grill is locked up permanently and will need to be replaced.
Hope this helped you and Happy Grilling. Thanks for choosing FixYa.
Aug 11, 2011 | Thane Q-BBQ Grill
When i push igniter it clicks but burners won't come on and i do not even smell gas , i burped it and turned gas tank upside down once, still won't work, grill is only 5 yrs old.
It sound s like the grill's regulator is locked up from "burping" the tank. Hopefully it's not a permanent lockup. To hopefully solve the problem, follow the steps below:
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it, as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
Jun 19, 2011 | Ducane 30400040 Stainless Steel Grill
New propane tank. Burner will not light, no gas flow. This was a replacement grill from coleman because they couldn't get the regulator. Starting to get very disgusted with this product.
jcw - It sounds like the regulator is locked up from turning on the gas tank valve. Happens a lot with the new OPD Valves on the grill tanks.
motion, slow).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Jun 18, 2011 | Coleman RoadTrip 9928-A50 Propane Grill
I can't get my Q to start properly. My start routine is to open the tank valve (20 Lb. with adapter hose) turn the control valve to start and hit the electronic start button. I get an immediate start at...
Yes, it does sound like a regulator problem or clogged burners, which causes delayed ignition.
let's start with the regulator first. Turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the valve is fully open, light the burner(s) as you usually do. Does the burner light, all the way around? If so, you solved the problem. Always, turn the tank valve on very, very slowly.
If that didn't solve the problem, you burner needs to be removed and thoroughly cleaned, including the venturi valve at the open end of the burner. If it still doesn't light as it should, the regulator needs to be replaced. If necessary, you can purchase it directly from Weber.
Hope this helps you to troubleshoot and solve the problem. Happy Grilling!!
Apr 23, 2011 | Weber Q Grill
I have a Cook by Number gas grill, model LG36C, that isn't cooking as hot as it should. I've disassembled all the gas lines and blew them out with compressed air. I cleaned the burner. I cleaned the...
Since your grill only has one main burner and it requires more gas to heat with than the side burner. I still suspect you have a grill regulator issue. But, if you've done your research, you know it's easy to solve. Turn the propane tank valve OFF. Disconnect the hose from the tank valve and wait at least 5 minutes before reconnecting it. Once it has been reconnected, turn the tank valve on VERY, VERY SLOWLY (slow motion, slow). Once the tank valve is fully open, turn your main burner on, light it and turn it to high. Do the flames appear to be higher than before? If so, light and turn ON the Side Burner. Now do all the burner flames appear to be higher than before? If so, you solved the problem. If not, either the grillhose/regulator assembly needs to be replaced or the Venturi Valve on the main burner needs some adjusting. As the air to gas ratio may be off sightly.
Hope this helps to solve your problem and Happy Grilling!
Mar 29, 2011 | Fire Stone LG36C Propane
Very low flame, can not see it burning bu feel heat
The Gas line Regulator to the tank is probably locked up. Turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the tank vale is fully open try lighting the burner and turn it to the highest setting. Do the flames look as they should? If so, you solve the problem. If not, are you sure you have enough gas in the tank to sustain the burners on high? If the gas level is Ok, then you will need to replace the Hose/Regulator Assembly, as the regulator has gone bad. You can purchase one at any home center or hardware store that sells gas grills. Take your old one with you for comparison purposes.
Hope this helped you solve the problem.
Mar 22, 2011 | Weber Q Grill
Weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 29, 2010 | Weber Genesis Silver B Grill
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Coleman White Rodgers Furnace Gas Valve S1-02543267000 Logo
55 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
