Professionalism in hospital theatres
How should you conduct your self with in a hospital theater as a professioanl
Manual for operating theatre policies and procedure
differs hospital to hospital , state to state , country to country
you will have to give more information or call the hospital customer relations and ask they for a theatre procedures statement
Jul 08, 2017 | Audio Players & Recorders
DAV-DZ777 no longer plays TV sound through home theatre. DVD, radio etc still works...
The hdmi needs to be ARC compatible and connected to the HDMI connected labled Arc.
Sep 10, 2016 | Sony Home Theater: DAV-DZ777 CODE FREE...
Hi, after aprx 1.5hrs of playing a dvd the home theatre system switches off, i then turn it back on and then aprx 1hr later after playing a dvd it switches back off, i repeat the steps above and the time...
Sounds like you have a cold solder connection somewhere on the main board or power supply. It opens when the junction begins to heat up after prolong use. It probably corrects itself when the unit is cold and the junction re-connects. Your best remedy is to inspect the boards and try to locate the bad solder connection. You can do this, but please be careful when working on live circuits, by using a non-conductive pointed tool and poke at suspected joints on the circuit board - if the unit begins to work again, Bingo, you found the problem. Good-luck!
Dec 16, 2010 | Samsung HT-X250T Theater System
I have a Sony STR-DE945 home theatre reciever, i keep gettin a clicking sound and then my surround speakers cut out.
It's probably your fan.
The system runs hot, as it supplies a lot of power to push your speakers.
The system knows that without a fan, it will overheat. If the fan gets hot, the system will throw its self into safety mode, to keep it from burning its self up.
Have a tech check your fan.
Nov 18, 2010 | Sony HT-DW610 System
Should my panasonic theatre system sa pt560 play cds
home theatre sa pa560w - turned it on and nothing, no warning
Mar 10, 2010 | Panasonic Home Theater System System
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
My Samsung Home theatre shuts down automatically after working for around 30minutes. After 15minutes if I switch on works for 30minutes & shuts down again. When shutting down there is a disply PROTECTION.
sorry to telll you this mate, but i bought a samsung ht-tz 312 at
chrismas and that had the same problem,
only mine would switch its self off after about five mins
i took mine back and they swaped it saying it was a design fault
ps mine did this from new sjr2009@hotmail.co.uk
Apr 29, 2009 | Samsung HT-Z310T Theater System
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
Computers & Internet Logo
David Payne
David Payne
