Question about Garden
How do sharpen a knife using a stone - Garden
    New Friend:
  • 4 Answers
Well scrap the rock on the tip
Posted on Nov 16, 2013
I recently bought a sharpening stone and 3 in 1 oil at a hardware store to sharpen garden equipment. Now I am not reall sure how to go about getting the work done correctly. I could use some advice.
If it is like the one I used when I cut meat you have to apply oil to the stone and push the part across the stone at a given angle checking often start with a course stone and move forward until lt is of proper sharpness
Jun 21, 2018 | Garden
Tip
How Do Knife Sharpeners Work?
Knife sharpeners are a way of preserving
knives and other such tools that have become blunt with use and therefore less
effective.
Sharpeners work by grinding the knife
against a hard, rough surface. Usually stone is the most common type of
sharpener but sandpaper (which has a soft surface but is hard), can also be
used.
You can take your knives to a knife shop
where they will sharpen them for you (on average once a year), but if you are a
keen knife user and want to keep your knives sharp and in excellent condition,
it might be worth buying a sharpener of your own.
To sharpen your own knives you’ll need to invest in a good whetstone. These are
stones that are available in fine, medium and coarse grits.
The sharpener will come with
instructions about the angle you need to place the knife at in order to sharpen
it.
You can also buy stones for polishing
and to complete the job properly, after you have sharpened your knife, you
should polish it.
on Dec 25, 2013 | Kitchen Appliances - Others
FILLET Knife sharpening
I use silicone carbide sharping stones , these keep things sharp and cool , as you never want to heat the blade while sharping them, takes the edge right off them (heat)
Jan 30, 2016 | Garden
Can I sharpen outliner blades on a sharpening stone by hand?
Sharpening stones are a myth you need to produce an accurate hollow grind which is impossible on a wet stone. See this link
http://www.angliaclipperservices.com/Clipper_Sharpening
Sep 11, 2015 | Health & Beauty
Can you use a knife sharpener on a bread knife?
If you were to use a knife sharpener on a bread knife in short term it might help the dullness issue slightly. However, the longer you use it the duller the grooves will be. A bread knife is a bread knife because of those grooves! My suggestion would be to use the sharpener on a bread knife for a maximum of four or five times. Anything after that would probably widdle down the grooves to the point where you are actually making the knife less effective.
Dec 26, 2013 | Kitchen Appliances - Others
What is the edge angle when sharpening a knife?
This is the angle between the blade and the stone.
Jan 24, 2013 | Kitchen Appliances - Others
What should I use for sharpening diamond stone or natural stone?
These days we can see that the artificial stones match in quality to natural stones and sometimes even better in sharpening performance due to consistency of particle size and control over the properties of the stones. When artificial stones gradually entered the market and were of good quality. Mines of Natural stone where closed and that caused the prices for natural stone to go higher. These days, getting quality natural stone is an expensive issue.
Jan 14, 2013 | Hunting
How to sharpen the blades on my Swiss army knife?
You can sharpen your Swiss Army Knife is using a circular motion. Start by holding the blade away from you at the proper angle. Run the blade of your Swiss Army Knife in a clockwise motion on the stone until you have sharpened that side of the blade. Turn the blade over and repeat with a counter clockwise motion.
Jul 09, 2012 | Camping, Backpacking & Hiking
Looking for sharping stone from efco fl64 /8 chain
There are multiple chain sizes 1/8", 3/16", 1/4", 5/32", 7/32" and 3/8" chains so the /8 chain number has me guessing. After the qurestions below, here is my best guess.
Also is this for a chain grinder?" or
Are you looking of a hand held type stone?
Aluminum Oxide Chainsaw Sharpening Grinding Stone
or Ceramic stone?
I will assume that your looking for aluminum oxide stones at this time.
http://www.oregonchain.com/homeowner/products/accessories/replacement_stones.htm
This is wide selection of sharpening stones.
You can also use hand held chain sharpening files of the same size that have shapening angles marked on the file set fixture.
Hopefully you have a sharpening guide that will keep your angles correct while shapening.
A safety note: Improperly sharpened chainsaw blades can be very dangerous to the user.
Thanks for using FixYa.
Kelly
Mar 10, 2010 | Oregon Scientific Garden
Berkel 827 sharpener not working properly
Your grinding stone stud is more than likely frozen try and lossen it up with a little penetrating oil take the sharpener off and work both stone back and forth untill they are both spinnig freely and remember do not apply either sharpening wheel on the knife for more than 5 seconds at a time you can burn the wheel and then it will never get sharp
Feb 03, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
