To find a crankshaft sensor for nissan almera 2004
SOURCE: 2004 Nissan altima 2.5 liter Crankshaft Position Sensor
Yes, the sensor can be replaced in your garage (if you have some decent auto repair experience).
This is not an easy job due to the location of the crank sensor.
Below are the steps I used to replace the crankshaft position sensor.
The steps are for a 2004 Nissan Altima with a 2.5 liter engine.
Nissan has a crank and cam sensor kit. I would not buy any aftermarket sensors because of the effort required to replace the sensors. (I do not work for Nissan). The information below is compiled of tips I found on the internet and my own experience. Even though these procedures may appear lengthy, it took me much longer to figure out the correct steps involved for this task.
Even though I have included all of the steps (and hints) I used… THIS IS NOT AN EASY JOB FOR THE “DO IT YOURSELFER”
CRANK SENSOR IS LOCATED AT FIRE WALL SIDE OF BLOCK BETWEEN MOTOR MOUNT AND FLYWHEEL. YOU GET TO IT FROM TOP.
Remove the (4) allen head bolts that hold the plastic engine cover. Remove the air tube that connects the throttle chamber to air filter box. Pull off the valve cover breather hose with the air tube. Now place a drop light under the two rubber heater hoses (at the firewall on the drivers hand side), shining the light forward towards the back side of the block (below the intake runners). To see the crankshaft sensor and connector, look between the valve cover and the throttle chambers (intake runners) on the drivers side, look straight down toward the ground… look for the sensor with a black wire connector with a green tab on the side, held to the engine block with a gold colored 10mm hex headed bolt. You will need to view the sensor from this position as you are following the steps below to remove and install the crank sensor. There is a large wiring harness bracket attached to the transmission bell housing that was temporarily unbolted to aid with the removal and installation of the crank sensor.
What turned out to be the biggest problem was the connector securing the wiring harness to the sensor. Unlike the camshaft position sensor connector that is removed by squeezing in on a tab located at the top of the connector, the crank position sensor was secured to the harness via some green colored push button assembly. To remove the crank sensor connector, the green tab must depressed ALL THE WAY DOWN (towards the block) UNTIL THE GREEN TAB LOCKS INTO PLACE - REMAINING IN A “PUSHED IN” POSITION (You should hear a “click”). I was able to accomplish this by viewing the connector as described above and at the same time, reach around the back side of the engine using a 6” – 8” flat blade screw driver (with a large head) and push the green tab in towards the block until it locked into place. After the green tab was depressed and locked, (still viewing from above) I repositioned my hand holding a smaller flat blade screw driver to gently pry the connector off the sensor inserting the blade of the screw driver between the bottom of the connector and the crank sensor (a slight twist should do it). I do not recommend pulling on the connector wires or trying to pull the connector off with pliers as damage may result - because in my world of auto repair, if there is a chance that something will break because I am not careful… IT WILL BREAK! After you have removed the connector and while viewing from above, use a ¼” drive ratchet with a 6” extension and a 10mm socket to loosen the gold bolt holding the crank sensor in place. I recommend that you loosen the bolt with the socket, then reach your hand around to the connector and remove the bolt by hand. After the bolt is removed, use an 8” slip jaw pliers - set at its widest opening setting – to grab the sensor. First twist then pull out the sensor.
Be sure to clean the inside of the sensor’s wiring connector with break cleaner spray and blow out with compressed air to get rid of any oil that may have leaked into the connector from the defective crank sensor… this is what probably caused the trouble code in the first place.
You are now ready to install the new crank sensor. If you purchased the crank and cam sensor kit from Nissan, make sure that sensor with white dot at bolt whole goes to the crank. Be sure to oil the rubber “O” ring. I was not able to get the green tab on the connector to snap back into place while the new sensor was installed in the block. I installed the connector to the sensor while it was out of the block – the green tab still did not pop back into its original position on its own – so…while the connector was installed as far down as I could push it, it used a small flat blade screw driver to push on the bottom of the green tab towards the top. That did the trick. While viewing from above, I placed the crank sensor back into the block. I was not able to get the rubber “O” ring to seat within the block by hand. I used the gold bolt to draw the sensor in while slowly tightening. HINT: I taped the outside of the washer of the crank sensor bolt to the 10mm socket to hold the bolt on place while I inserted the bolt into the block… you can do this by hand, but I didn’t want to drop the bolt . I also taped the socket to the ratchet extension so the socket would not get stuck on the bolt (it’s a snug fit down there).
If you were able to accomplish the above procedures, the cam sensor is a snap to remove in install. It is located in the driver’s side portion of the head facing the wheel.
Remember to reinstall all brackets and items that were removed.
Posted on Feb 17, 2009
polarcycle
  • 1392 Answers
SOURCE: 2004 DODGE STRATUS 2.7L, Location of Crankshaft Position Sensor?
it is located on the right side of the motor, in the trans area. Actually in the bell housing.
Posted on Jun 23, 2009
SOURCE: crankshaft position sensor for 2004 nissan sentra.
will the crank sensor cause the vehicle to shut down while running?
Posted on Aug 06, 2009
SOURCE: how do I remove the service spanner symbol from a
Try this: With the ignition ON but radio OFF, press in and hold the INFO button and turn volume control until the menu appears. Now choose CONFIRMATION and Enter. Go down and select SERVICE and press Enter. Select RESET and then Enter. Backup to the main menu and now turn ignition off. This should remove it.
Posted on Feb 14, 2010
SOURCE: crankshaft position sensor location on 2004 chrystler pacifica
can u please tell me where on my 2004 chrysler pacifica is the crankshaft sensor located?
Posted on Apr 25, 2011
Nissan almera tino Crankshaft sensor location, please help as I need to change mine, already got part
U sure its the sensor..dont guess. Cud b an egr valve or vacuum leak. Car wudnt run at all w a bad cranksensor. Git car scand to target area
Jan 12, 2016 | Nissan Cars & Trucks
Location of nissan almera tino crankshaft sensor
if you are under the car it should be on the firewall side. It is black piece or a light grey color.
Jan 08, 2016 | Nissan Cars & Trucks
I replaced timing chain wont start
Confirm the timing marks were aligned properly by manually rotate the crankshaft up until piston number one is on a compression stroke, try to do this twice and make sure that the timing marks should be aligned accordingly with piston number one in top dead centre.
Jul 10, 2014 | 2004 Nissan Nissan almera tino
Abs rear wheel sensor offside
When you replace a speed sensor, the light should turn itself off after driving it. If it does not go off, than there is another problem.
Mar 03, 2014 | 2004 Nissan Nissan almera tino
How to replace a nissan almera timing chain
Hi all it is with out doubt a major blunder by Nissan to fit a Renault timing chain mechanism to the almera and other Nissan engines. I have dealt with many a customer with an engine light on hoping that a crankshaft sensor would sort the issue out, Nissan will charge in excess of 750 euro to replace the timing kit and having it replaced you might hope to get 120k from the car well I have come across engines only covering 30k buyer chain failure, beware if you are doing a chain replacement your self use (oe) parts often spurious parts don't have the paint marks on the chain to aid setting the timing ,
Oct 17, 2012 | Cars & Trucks
2005 nissan almera,1.5letre.. fault code po725
P0725 NISSAN - Engine Speed Signal
The P0725 Codes is triggered when TCM does not receive the engine speed signal from ECM.
The Engine Control Module (ECM) monitors the engine speed through the Crankshaft Position (CKP) sensor with the engine running, and send signal to the Transmission Control Module (TCM).
Symptoms:
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes:
- Open or shorted CKP sensor circuit condition
- Poor CKP sensor electrical connection
- Check communication error between the ECM and TCM
- Failed CKP Sensor
Possible solution:
Very common problem with Nissan vehicles, usually replacing the Crankshaft Position sensor takes care of the problem.
Keep us updated.
Feb 12, 2011 | 2005 Nissan Altima
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
