INDESIT WIB101 WONT SPIN
Machine has been working fine.Today it has gone through the rinse cycle ok,then begins the spin cycle (although doesn`t actually spin round)then just stops.Then it`ll go quiet for about 10 mins then do the same noise(as though it`ll start the spin cycle)then it stops again. If I switch the power off and on again it does the same thing. Machine is about 6-7 years old and has had quite heavy use.
    Problem Solver:
  • 13 Answers
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Posted on Nov 16, 2013
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
rachael
  • 4 Answers
SOURCE: Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
Posted on Dec 17, 2007
  • 6 Answers
SOURCE: Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Posted on Feb 13, 2008
  • 7 Answers
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Posted on Apr 08, 2008
  • 1028 Answers
SOURCE: Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Posted on Oct 25, 2008
Operation of machine wash, rinse, spin
at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
Mar 04, 2014 | Indesit Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Washing machine switched on, although timer runs it's cycle there is no action from the machine!
sounds like the motor or motor brushes worn,you 1st need to make sure its pumping ok. put it onto a spin make sure pumps ok,if no spin then check your motor...
Jun 19, 2010 | Indesit WA 125 Front Load Washer
Indesit programmer has a mind of its own
I have LG Washing Machine WF-S6607 when I START after 5 Second it will be stop and alarm to come up on Rinse MODE. what I do?
Oct 17, 2009 | Washing Machines
Water not draining although spin still ok. Then went bang!
Called out a plumber who diagnosed that the machine was not worth mending. He charged me £25. Now have new Indesit WM.
May 23, 2009 | Bosch Washing Machines
Indesit wg1185w wont wash
Hi, I think you will find that the heating cycle has failed! Does the water heat up? If not check the heater and the thermostat if you have one. No heat No wash cycle..!
Get back to me......
Jan 02, 2009 | Indesit WA 115 Front Load Washer
Indesit w123 shaking
I had the same problem the drum when in spin cycle with the machine almost walked out the door shaking violently as if it was possessed. Check the drum on the inside of machine as most times it has some kind of screw to hold it in place for transporting etc. I did find on the other cycles it worked fine except for the spin cycle, and l have this machine in my caravan near my bed so you can imagine the ferocious noise and how scary it was, and it was a simple error on our behalf. I hope this resolves your problem. Kind Regards Karen.
Jun 24, 2008 | Indesit W 123 Front Load Washer
Got a new washer that has button to drain water but its not draing water or doing spin cycle and keeps coming up with error its an indesit wib101 washer it wont finish any cycle at all
check out the DRAIN MOTOR PUMP ,it could be clogged , take it out , inspect it , clean it , and try again , hope this helps AJ
May 13, 2008 | Washing Machines
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
