Question about Maytag PDB3600A Built-in Dishwasher
Door hinge sprung
We were loading the dishwasher and went to shut the door and accidently pulled up on the door and now the top of door is above the top of dishwasher by about 1 inch and we can not get the door to go back where it is supposed to be.Help it can not possibly be that hard to fix.
    New Friend:
  • 14 Answers
From the bottom try to pull straight out and then push down. Do both the left and right sides have the issue or is it specific to one side?
Posted on Nov 16, 2013
83 olds car doors,will not close on one side,the other won't open or close
doors do not alter in their openings unless the following has occurred
accident that alters the door opening shape or alters the door hinge position
badly worn hinges
people hanging off open doors or lastly
the sill panels ( rocker panels ) under the door that are part of the door opening and body strength have rusted away under the car allowing the door opening to alter and affect the doors closing properly
Oct 19, 2015 | Cars & Trucks
How do u repair sprung door hinges
If you could tell us why you think they are sprung and the make and model of the machine that would help.
Oct 05, 2015 | Dishwashers
Sprung door
Sometimes depending on the how the damage was incurred
Apr 11, 2014 | 1989 Buick Regal
Sprung door
Go to the companies website, and you can order new hinges.. (cheap too) easiest way... Next time, don't forget to shut the door... :P
May 10, 2012 | Dryers
The dryer door will not stay closed, so it shuts off after starting
Check your door latch.Shut the door and pull it open. If it pulls open very easily then you need to change the door latch. Make sure the door is not sprung
If it is then put a small screwdrive in front of the latches inside the door and push very gently in degrees. Then remove the screw driver and test it. Do this over and over (very gently) until it closes properly.
Or you can remove the hinges off the door and straigten them.
Leo Ponder
imufo2@sbcglobal.net
Jul 30, 2010 | Kenmore Dryers
The refridgerator door won't seal propertly. We
It could be a bad seal or the door could be sprung without seeing it it is hard to tell. Check the hinges make sure door is properly attached. If it appears to be sprung try pulling on the top of door and pushing on bottom to spring it back into place.... Just not too hard.
Mar 17, 2010 | KitchenAid Superba KSRS27CN Side by Side...
Leaking door on Bosch dishwasher
I DONT THINK THERE IS A ASSEMBLY MANUAL BUT THE DOOR HINGES IS LOCATED UNDER THE LEFT AND RIGHT SIDE OF THE MACHINE. YOU HAVE TO CHECK THE HINGE PULLEY THEN CHECK THE LOCK.
Sep 23, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Sprung the door now it won't close was emptying it and tripped over a dog
You probably need a new dishwaher. I have seen a few sprung door hinges repaired which worked OK, but most still leak after a costly repair. Your call and good luck. Ken
Apr 06, 2009 | Maytag PDB3600A Built-in Dishwasher
Door hinges appear to be sprung
pull up alittle on door then back down to seat the hinge
unless you put something heavy on door , this should work
Mar 02, 2009 | Frigidare FGB24S5DC Gas Single Oven
Squeeking, swaking door springs
Hi there
Thats a common problem with sprung door hinges, get some WD-40 lubricant spray and spray the spring until the squeaking stops.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | KitchenAid Dishwashers
Maytag PDB3600A Built-in Dishwasher Logo
73 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
