Model t2885 heard pop one day then e logo broken
E- machines t2885 model e logo broken is it a monitor problem or desktop problem
Give more details. Do you see anything on the screen? Are there lights on the computer and nothing else, fans going ect?
Nov 16, 2013 | Computers & Internet
Can't open control panel on my T2885 Emachine
Sounds like you need to run anti-virus, and possibly reinstall your Operating System.
Mar 01, 2011 | E-Machines T2885 PC Desktop
Popping or knocking heard in front end when riding
Sounds like the Spring may be broken or there is another loose front end part such as a ball joint or a spring seat or something like that.
I had a broken spring on my 1990 Cadillac Deville and didn't know it until looking at it up under the wheel, and experiencing a popping or knocking sound when turning.
It could also be the bearing cap area problem.
May 12, 2010 | 1998 Cadillac DeVille
check your stabilizer links common problem.one will have broken causing your noise.
Mar 20, 2010 | 1998 Cadillac DeVille
I have a GE Profile front load washer, model WPXH214AoCC..one day it was spinning and all of a sudden i heard this big pop..now, when it spends, it sounds like it will take off and fly. the noise is so...
You may have a broken tub support. This repair won't be cheap and I would not advise self repair as this is a complete tear down of the machine.
Feb 28, 2010 | GE Washing Machines
We turned it off heard a noise and now the red power light just blinks and the power will not come on again. Toshiba TV Model #32SF62 Serial #11100308
what was the noise? POP!
If so then a capacitor on the power board has fried itself. Most problems where the lighyt blinks and nno pic or sound or a breif logo and then black are as a result of a faulty IC or capacitors on the control board
Sep 07, 2009 | Televison & Video
Loss of steering
Obviously in both cases some part of the steering linkage broke off (steering shaft, pitman arm, idler arm, tie rod or tie rod end... etc... Could be a number of things, depending on the location of the broken part) In the second case (still had steering for 2 days), that was just a streak of luck and the broken part stayed in place just enough one way or another for a few more days.
Jan 13, 2009 | 2000 Ford Econoline
Panasonic DLP
If it has "Popped" then I would expect a rather catastrophic failure, and Lamps don't go "Pop.. they just fail more likely a Capacitor, Resistor, maybe even a semiconductor... so it's off to a reputable repairman get a "quote" and proceed from there.
Jul 22, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Wiring diagram for T2885
Give me also model serial number (printed on your motherboard or on seller's receipt).
http://www.dealtime.com/xPF-E-Machines-Desktop-with-Intel-Celeron-Processor-2-8GHz-T2885
Feb 17, 2008 | E-Machines T2885 PC Desktop
Televison & Video Logo
Top Televison & Video Experts
