Question about Humax FOXAT HDR DTV Receiver
Hard disk capacity has fallen in spite of deleting most of recordings
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 141 Answers
This can happen occasionally. It seems that the answer is to reformat the disk - having watched or transferred any required recordings first.
Posted on Jun 06, 2014
I have a Sagem recorder DTR6400T/6700T a number have faults have occurred....can't record,states HDD has reached its recording capacity but only used 5%.......when deleting,comes up with "error during
One way around it would be to reformat the hard drive. If it has that option. However you would delete any recordings on the drive.
There could be read errors on the drive too, which might be cured by clearing everything off.
Does the drive have a fault or status check? If it does try that first.
Jan 04, 2018 | Televison & Video
Sagem PVR disk full error
Most likely a hard drive failure. Something called spinal failure can cause an issue that sounds like this.
Aug 30, 2012 | Sagem Televison & Video
What hard drive is used in wj-hd316a
The hard disk is divided into three partitions: "Normal Recording,"
"Event Recording," and "Copy." Image data is automatically
recorded to the appropriate partition according to the recording
mode. For the normal recording partition, the data is overwritten
when the capacity is full. The event recording partition prohibits
overwriting to protect data. Copy partition prepares data for
retrieval to external medium.
Hard Disk Partitioning Function* automatically
selects the partition to be recorded.
RAID5 distributes image data to multiple hard disks in the
extension unit. Upon hard disk breakdown, lost data can be
restored from other hard disks. When using one WJ-HD300A
Series unit, mirroring function is available for data backup.
RAID5 / Mirroring Function
Playback VMD
One VMD area can set one
playback image for motion
search.
WJ-HD300A Series
Conventional
(* 10, 13, and 16 screens are available only with the WJ-HD316A.)
Even when images from multiple cameras are displayed on a multi-screen,
live monitoring can be achieved on all cameras at a full rate of 60 ips
(image per second). Experience real-time,
full surveillance with
full-rate video images.
Full Rate Live Multi-Screen
4-window 7-window 9-window 10-window* 13-window* 16-window*
Multi-screen in versatile variations
GUI Setup Menu
Time Table
Actual recording result (Example)
hope it helps
Feb 25, 2012 | Panasonic (WJ-HD316A/500) (WJHD316A500)...
Too small capacity
Depends on what you are using the hard drive for. For example if this hard drive is going to be used for multimedia then I would recommend a hard drive around 120Gb to 1TB, but if it's for a small office with MS Windows XP installed it should be just enough to host the operating system and a limited amount of programs, hope this help, best of luck
Feb 02, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
How to re-join two partitions on one external hard drive?
You cannot. You delete both and then make one partition.
There is software available that will let you resize a partition. (E.g. Acronis Disk Director). In this case you delete one partition and the resize the remaining partition to use the space created.
Most important: Back your data up to another hard disk before making any changes to your disk.
If this helps please vote for my solution.
Oct 01, 2010 | Verbatim External, USB 2.0, 750GB...
Will Not print from my MacBook Pro in spite of trying both wireless and corded connections. Copies perfectly.
Deleted the original CD download. Then, reconnected the corded connection, as there is no wireless capacity. With both computer and printer reconnected, repeated the entire download process, and deleted all prior printers used by computer. System works fine if connected now.
Oct 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Can someone tell me how to delete recordings and /or downloads currently on the hard disk. I have tried to sync to a blank playliast with no avail and the manual was badly drawn up
Hi...
If you want to delete recorded song, the easy way is you can plug your hard disk to your computer then after your hard disk detected you can delete now your recorded music..
Good luck !!!
Regards
PCmania
Jul 07, 2009 | iRiver H10 MP3 Player
A Non Disk Hard Drive "?"
Yes there are solid state hard drives available but they are not cheap and at present they cannot match the capacities available in the standard hard drives.
Check these comments I downloaded fron the WEB.
As prices continue to drop, however, flash-based SSDs (solid-state drives) have become viable options for handling primary storage requirements. Moreover, today's roomiest SSDs have 32GB of memory, enough to do more than satisfy basic storage needs - making them competitive with 1.8in hard-disk drives, which range in capacity from 30GB to 80GB.
These SSDs, available from companies such as Samsung and SanDisk, are lightweight (the SanDisk UATA 5000, for example, weighs 59g) and can be found in the US in laptops from Dell, Fujitsu and Toshiba.
Are they worth the extra cost? In spite of price drops, SSDs cost £200 to £250 more than ordinary hard drives of the same capacity. To justify the price difference, SSD laptops must demonstrate significant performance benefits over notebooks equipped with standard hard drives.
Feb 10, 2009 | IBM ThinkPad T21 Notebook
Humax FOXAT HDR DTV Receiver Logo
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
