Question about Pioneer DEH-2700 CD Player
I hooked all the colors corectly to old harness wont turn on?
Can i hook orange and red together?
SOURCE: need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
Posted on Jul 29, 2008
starlet4life
  • 89 Answers
SOURCE: ive got everything hooked up right but the cd player wont come on
Sounds like the ignitionwire aint hooked up or turned ON...hehe...;)
Posted on Sep 28, 2008
blueextc3221
  • 15935 Answers
SOURCE: pioneer dehp3100ub.stock speakers wont work with unit?
If the vehicle has a premium sound package - you need to use the remote wire to turn on the factiry amplifier.
If you want to use the power from the radio for the speakers, you must buy and install a factory amplifier bypass harness.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 19, 2009
futurework
  • 70 Answers
SOURCE: i have an after market pioneer car stereo and not
red is usually ignition switched power from the fuse box and the yellow is continuous power to the deck. blue with the stripe is usually a voltage output from the deck to control the on/off of an external amplifier. If you hook the deck up and the memory stations do not save after vehicle on/off cycle of the ignition swap the yellow and the red wire and they should work. One is power all the time to allow the deck to store memory and the other is the main power to the unit.
Posted on May 05, 2010
kenw392
  • 2226 Answers
SOURCE: red,yellow and blue with stripe hooks to what into harness
some decks have a solid blue for power antenna and blue with white stripe for amp turn on. if you have neither a power antenna or amplifier, i would not worry about connecting those two wires. do makes sure they are capped off and have no bare wires showing, as they are hot when the stereo is turned on.
My new rear car speakers wont fit on the wiring harness in my truck.... Can i buy a certain adapter for that
your going to have to cut the wires and use the red connectors that you crimp (squeeze ) shut on each end. before you crimp them just twist them together and turn the radio on listen and see which way you hook them up has a deeper bass. cause if you hook thethe neg to the pos it wont sound very deep and hind of distorted
Jan 27, 2013 | 1999 Chevrolet Blazer
Honda passport fuel harness
If it is the correct fuel pump - where it unplugged, it should just plug in where the old one did.
Mar 14, 2012 | 1998 Honda Passport
O5 Ford Escape I have to change the Wiper motor plug and the wires on the new plug are all black. I need to know which wires hook where. I need a wire diagram
The plug on the new harness is numbered.(look at the body of the white plug ) The Wires from old one are colored. they go together like this.
1 is blue and orange
2 is black and pink
3 is black (ground)
4 is Black and white
5 is Dark green
Aug 13, 2010 | 2005 Ford Escape
Installing Kenwood KDC-MP345U into a travel trailer. Trailer is pre-wired for deck. Have Orange (hot) & White (ground) from trailer converter to deck. Hooked up yellow (battery) wire from harness to...
the power terminals from the trailer arent direct connected to the battery terminals.when you are plugged to the mains the battery is charging and disconnect [via a relay perhaps]the orange terminal from batt+.try to make anew connection from the trailers battery terminals with a new fuse separated from all trailers circuit'use 2-2.5 mm*cables and a 15amps fuse.connect the yellow and red to+batt and black to- batt.
Jun 05, 2010 | Kenwood Car Audio & Video
We had a clarion reciever with tape deck in our boat and found another clarion reciever with two new speakers and two good 1996 speakers which had not weathered. The instalation was difficult but the...
As long as you have connected the ground(black) try adding one wire at a time to the live(red). If possible try connection each wire one at a time to the power line and then both together. If nothing has blown(fuses) and the unit starts working then you can try by trial & error method the remaining wires. You should be able to figure out which wire is required and if there are any extra wires like cellular phone(mute) and then decide whether to connect them or keep them open.....sodeep
Jul 27, 2009 | Clarion DB245 CD Player
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Sony cdxm610
Red- Constant Power -
Yellow - Ignition power - 12v
Black - Ground
Blue - Ant & memory
Orange - Dimmer
All the wires that have 2 of the same color are speaker wires
ex - green, and green with stripe. The one with a stripe is the Negitive
In most cases the red and yellow need to be together to get the cd player to start if you dont have 2 hook ups for both constant and ignition powers.
The black ground can go to any bolt that is screwed into a metal grounded object. The blue and orange are not needed unless you have a harness that supports the dimmer and memory feature.
If you cd player works with this but wont keep settings or time, hook up the blue to the power so it can constantly save your settings.
All the speaker wires a total of 4 diffrent sets of 2 can go anywhere as long as you dont want to fade or bal your speakers if so you need to test them by hooking up 1 speaker at a time to find out where it leads to. GOOD LUCK
And
Thank you for your question
Aug 04, 2008 | Sony CDX-M610 CD Player
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
Pioneer DEH-2700 CD Player Logo
23 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
