Ruud rcba3765gg17 Change the filter
    Master:
  • 613 Answers
The filter is located in the return air plenum and should be replaced at least twice per year.
Posted on Dec 14, 2013
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-14J11SFA. What size replacement filter can I put in this system?
You can measure what size and use any after market permanent filter. Measure the opening to the rear and across the opening. Should read as ?x?
Dec 03, 2014 | Ruud Heating & Cooling
How to change air filter comfortmaker
air filters are behind return air grille.
Jan 07, 2014 | Ruud Heating & Cooling
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-21J18SHG. What size filter should I put in this system?
The Ruud UBHC-21J18SHG has a nominally 21" cabinet width. So the needed filter is 19.75" x 21" x 0.375" (502 mm x 533 mm x 9.525 mm). The Ruud part number for the filter is 54-23217-03 .
The specifications sheet for the Ruud UBHC series air handlers is available here: http://www.coburns.com/images/PDFs/h22-517rev1.pdf . The filter size information is on page 3 and page 12.
I've found the filter at one online vendor: http://www.patriot-supply.com/products/showitem.cfm/RHEEM_68_101807_03 . (This is a common filter that fits several manufacturer's air handlers.)
I hope this helps.
Sep 10, 2011 | Ruud UBHC Air Conditioner
Ruud air condition
You must be kidding. You want a video?
If the filter is in the air handler, it is in the bottom. Often filters are not in the units themselves, but in the main return grill in the ceiling. But if it is in the unit then:
Turn the unit off at the thermostat. (That way the fan is not sucking the filter up,) Then take the bottom door off. It is a small door and a pain, but you can do it. Pull out the filter. It is a washable black plastic framed thing. Then wash it and put it back in. Then make sure to put the door back on and turn the thermostat back on.
Jun 14, 2010 | Ruud UAPA024 Air Conditioner
Wher is the filter
filter should be beside or inside the furnace fan compartment....if you have an Electronic Air Cleaner (EAC) thyat's working . no other filter is required 29637bd.jpgd88e24f.jpg
Oct 31, 2009 | Ruud UBHC Air Conditioner
Replacement of filter on Ruud Achiever series heat pump/AC
You must first remove the blower compartment panel. The filter should be in there. However, since this unit is in a crawl space you may have a return air filter grill. Look at your return grill. Does it have a filter? If not does it have latches so that you can open it? If so measure the opening and install a new filter there. I hope this helps. Please don't forget to give me a Fixya rating.
Feb 21, 2009 | Ruud UBHC Air Conditioner
How do I change the filter in my Ruud Achiever series
I'd look in one of 2 areas.
1. often there is a central return in the house. This is the place where the air gets pulled back to the unit and is likely very close to your thermostat. Check for a filtered louvered grill there and see if your filter is located here. If so, you can access the filter by opening the filter frame with a screwdriver or even a coin.
2. Otherwise I would expect that your filter is on the return-air side of your air handler (where the blower is) Older models have the filter actually inside the air handler in the blower compartment. Newer models may have a small separate filter door. I'd look in these areas.
hope this helps
ghoff
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
