Question about Bosch AQUATAK 110 Pressure Washer
Oil leaking from bosch aquatak 110 pressure washer
It is leaking from a tiny hole underneath, i never even noticed the oil tank until i smelt the leak just now while i was washing the patio
SOURCE: bought bosch aquatak 100 pressure
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
Posted on Jan 20, 2011
SOURCE: water leak from main housing
Any solutions Paul. I have the same problem
Posted on May 31, 2011
  • 18 Answers
SOURCE: Our Bosch washer leaks but only during the spin cycle.It is a Classixx.
Try cleaning the detergent draw somtimes this can cause water to spill out and ofcourse check the filter and exit pipe :)
Hope this helps
TalkAppliance.co.uk
Posted on Apr 23, 2012
biggn316
  • 16 Answers
SOURCE: I have a Bosch Aquatak 115 plus pressure washer that has a blockage on the inlet. I suspect some small particle in the water supply has caused the problem as it occurred in the middle of a job. I wa
need to clear out your total inlet system and flush the pump out if needed and install either inline filter or screen
Posted on Oct 17, 2012
SOURCE: Bosch nexxt washer is leaking from underneath
I found out why mine leaks. In the Bosh design there is a trap molded into the soap dispenser plastic tray. This tray or trap has a wide open path to the inside of the washing machine. We are using the tide pods as a detergent. Two things are going on here. This trap fills up with water immediately when water is cycled into the machine. The second thing is the pods partially dissolve and leave a gunk that blocks the water pathway to the drum. This blockage eventually allows water to pass however when the pressure is high and this blockage is restricting the water level rises and the trap dumps out into the washer panels. This water immediately leaks down and out the bottom. Observation when I disassembled the machine the trap was moldy and stinky. Water stains were running down the inside. Maybe the engineers at Bosch should look into this.
Posted on Apr 07, 2013
I have a 1995 Toyota corolla and I recently noticed I had a gas leak I sealed the hole with JBL epoxy to hold me over until my new tank arrives but it looks as if there is oil mixed in with the gas .
Keep checking the oil level and the transmission fluid level to make sure they stay full, but there should be no oil in the gas tank.
There may be water, however, and it may be brown like oil.
Water will sit in the bottom of the tank and make rust underneath the gasoline, since gasoline floats on water.
Dec 29, 2016 | 1995 Toyota Corolla
What is the quantity & the type of oil of Bosch Aquatak 10 pressure washer? Thanks
The link has changed in the meantime i see
You can use every EP zinc-free hydraulic oil what you want for it PERLUS ZF46 is a very good alternative
Jun 19, 2016 | Garden
Not using shampoo
use nozzel with big hole or open nozzle up if adjustable
Apr 20, 2014 | Bosch AQUATAK 150 PRO X Pressure Washer
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
Nov 08, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Oct 14, 2012 | Bosch AQUATAK 115 PLUS Pressure Washer
Bosch logixx 1600 exoress from leaking underneath approx middle
This video will show you how to change a door seal on this Bosch front loader washing machine
May 20, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water leaking from top of expansion tank.
have you replaced the bleeder screws? and the expansion tank cap they both have O-rings that compress and will fail over time also check the hose at the top of the exp tank it also has o-rings inside it
Apr 03, 2009 | 2000 BMW 3 Series
Bosch AQUATAK 110 Pressure Washer Logo
255 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
