Question about Rotora 2003 DODGE RAM 1500 PICKUP RP.08970.1 Brake Pads - Ceramic
My head light is broken on the driver side
The light on the left stopped working, and the rest do. The high beam works, the low beam stops. I've change the bulbs, they are brand new. Any idea how to fix it?
    New Friend:
  • 22 Answers
Check connector for corrosion, clean contacts with wire brush or replace.
Posted on Nov 16, 2013
Driver side low and high beam on but dim. Passenger side low beam normal but high beam on and dim
I would check for the groundwire continuity
Driver side - dim low beams and no hi beam - Subaru Outback ...
www.subaruoutback.org > ... > General > Electrical & Electronics
Oct 11, 2014 - Hi everyone, My drivers side headlights are dim on low, (car has separate bulbs ... When the headlight switch is turned ON, but for low beams, ...
Driver-side Low beam Not Working (electrical issue not bulb ...
www.hummer4x4offroad.com/.../showthread.php?...Driver-side-Low-be...
Mar 12, 2015 - 10 posts - ‎4 authors
The high beam continues to work on both sides...I pulled the Driverside headlamp fuse and then both left and right beams lit up but very dim.
High beams ok, but not low beam - one side only - TDIClub Forums
forums.tdiclub.com > ... > VW MKIV-A4 TDIs (VE and PD)
Jan 23, 2014 - My driver's side lights are working fine - high and low beams. ... But it definitely looks like the big lamp on the driver's side gets brighter when ..... Drivers side headlight is very dim on low beam and goes out when on high beam ...
Dim driver's side headlight (low & high beam) - GrandAmGT.com Forum
www.grandamgt.com > ... > Technical Q&A
Dec 11, 2002 - 6 posts - ‎4 authors
Jan 04, 2016 | Cars & Trucks
I have a 98 Chevy Malibu My car was hit on the driver side weeks later the headlight stopped working I replaced the whole headlight nd bulbs The auto low or high beams work but only in one head light
You may need to change the wiring harness.
2000 malibu headlight problem - Tech Support Forum
www.techsupportforum.com > ... > Automotive Support
Dec 14, 2008 - 8 posts - ‎2 authors
I have a 2000 chevy malibu with headlight problems. ... High beams work correctly.... I suspect a ground problem but cannot locate the ground cluster. ... Grouped together there, one pink wire to the Headlamp Switch, and one to ... my Wife's car has lowbeam on the left side that just won't work and now the ...
Dec 20, 2015 | Cars & Trucks
Hello, I have a headlight problem on a 2004 chey calvalier. All of my lights work except low beam on drivers side. Fuses on left and right headlights are good. I've switched bulbs as well and nothing...
I would focus on the connections going to that head light for the low beam. I agree, it is not the switch, otherwise other side low beam would not be working. It is most likely bad bulb inlet( if it i separated bulbs for high and low) or it is the connection going to the low beam that operates it. Hope this helps. Don't waste your time on switch, it is not that.
Jun 08, 2011 | 2004 Chevrolet Cavalier
One highbeam light was very dull like a semi broken wire, so i rewired the bad side to the good side it worked for a couple of flashes to test , high low beam , then no high beam lights at all, are they...
you have a wiring problem, look up cavalier headlight wiring on the internet, there is a harness connector under the battery that sometimes goes bad, or the wires are broken inside the insulation, usually in the front harness, the head lights hi and daytime lights are controlled through the ecm and low beam is on a separate circuit, i have also found problems in the switch or the drl module in the fuse box, any mor questions mail me
Apr 20, 2010 | 1998 Pontiac Sunfire
I have a 2003 chevy cavalier. headlight issue
The blinking light is telling you that you have a headlight out, if you look the service light should be coming on when the light stops blinking.
Replace the head light and all should be fine.
Feb 23, 2010 | 2003 Chevrolet Cavalier
Audi A4 2002 Low beams & Right front turn signal stopped working
For Audi A4 the fuse box is located on the left side of dashboard behind a plastic cover (for left hand steering wheel vehicle). On inner face of the plastic cover you will find the fuse diagram.
First fuse on first row from left upper corner is Fuse Nr.20 = F20 (15A) - RH headlamp low beam, headlamp adjustment.
First fuse on second row from left upper corner is Fuse Nr.21 = F21 (15A) - LH headlamp low beam, headlamp adjustment.
Feb 15, 2010 | 2002 Audi A4
Low beams stopped working high beams work fine
Either both bulbs are bad(I've seen it before) or your
dimmer/headlight switch is bad. If you can without pulling the bulb, pull plug from the light. If it's a 4 lamp system pull the low beam. Do this on the left side as the right feeds from the left. With a 12v test light, check for power. (with lo beam on) if you have
power, change the lamp, if you don't it's most likly
the dimmer switch at the steering collum.
Hope this helps Good luck
Jan 21, 2010 | 1987 GMC VanDura
I own a 1995 honda odyssey minivan and the drivers front head light is not working because of the wire connection? what do i do to fix this problem because I got stop for having only one headlight? thank...
hello annette from uk you think it may be connection ?? is head light not working on dipped beam? but high beam ok ? if so it may well be the low beam element in h/light bulb has blown however you could also check the fuse as each side head and sidelights have their own fuse check handbook for position of fusein box if ok then you can try the other head light bulb from other side into the plug connector of drivers side and if this works on high+low beams ? your old bulb is blown feel sure you can do these checks !? approx price of new bulb in uk £4 -50 but carry out above checks !st b 4 you buy bulb ? if it is a bad connection on plug ? another bulb will have same problem hope you understand all above ? and wish you good luck from n/west uk
Oct 30, 2009 | 1995 Honda Odyssey
Rotora 2003 DODGE RAM 1500 PICKUP RP.08970.1 Brake Pads - Ceramic Logo
Top Rotora Computers & Internet Experts
jeff5may32
Adam Truesdale
Tim Marx
Tim Marx
Are you a Rotora Computer and Internet Expert? Answer questions, earn points and help others
