Question about Welding Tools
Century wire feed welder
My 80GL spits, sputters and pops when trying to do any welding, can't run a bead and makes a mess! Any ideas?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Sounds like you need to learn to weld
or Metal is way rusty or bad Ground or Amperage too high
Posted on Nov 21, 2013
4 Suggested Answers
wiringlunati
  • 576 Answers
SOURCE: I have a century 140 welder It does seem to have
That doesn't sound right. Double check your ground and the tip the wire feeds through -- if it is damaged/worn/burnt it will not transfer full power to the wire. After that, it would be time to check the connections from the transformer to the leads for dirt/loose connections.
Posted on Nov 29, 2009
  • 81 Answers
SOURCE: wire speed or heat problems
can you adjust your voltage settings? you may be welding on material that is thicker than what your machine is designed for. your ground clamp may be loose or dirty.
it should sound more like bacon frying than popcorn.
Posted on Apr 21, 2010
  • 1212 Answers
SOURCE: Wire feed speed problem
Check the speed control board's voltage from the fan. If you are below 20 volts, 1- oil the cooling fan bushings to see if that helps. Otherwise adding in a discrete 24 volt 1 ro 1.5 Amp "control" transformer and a 2 ohm 50 Watt resistor in place of the fan's 24 volt tap (it rarely gets to 24 volts) should bring your speed up.
This does assume the board is fully functional.
Posted on Dec 29, 2011
Dec 27, 2011 | Welding Tools
When i go to run a bead the machine pops and then it shuts off
It shuts of because the machines over heats, or poor voltage.
Nov 22, 2010 | Lincoln Electric LE 83180 Century...
Welder will only weld for about three inches on high
If it won't push wire through gun you might need to tighten wire rollers, or check the liner for bad spots.
May 13, 2010 | Century 80GS Flux - Cored Wire Feed Welder
Weld arc not stable. Wire feeds, good ground,
Arc blow could be the cause! Put your ground on the work piece and weld away from it. If you weld toward a ground clamp the magnetic forces will blow your arc around sometime. When taking a cert this simple mistake can make or break ya on your cap or reinforcement beads.
May 09, 2010 | Hobart Handler 140 Mig Welder
Wire speed or heat problems
Apr 11, 2010 | Clarke Power Products Clarke 130EN...
Was welding and welder quit acking wire feed and gas still work i have a century pro wire welder model 170gs
Check earth wire has not become dislodged,
Pop the cover and check for burnt terminals, often overheating of the transformer can cook a terminal, easily cleaned up and replaced.
Mar 31, 2010 | Welding Tools
Weld arc not stable. Wire feeds, good ground, everything looks good, liner pulled and cleaned, new tip.
Try moving the tip closer to your work and try turning your wire speed down
Most people want to crank up the wire speed when it spits and sputters
Turn it down
See if this helps
Mar 16, 2010 | Hobart Handler 140 Mig Welder
I have a Hobart handler 120/90amp wire feed welder.When i try to weld,all i get is a small spark.I turn it off,turn it on and it does it again.The wire feed works good,it just sparks,but will not keep...
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
Feb 01, 2010 | Hobart Welding Tools
I have a century 140 welder It does seem to have any power. I'm using .023 wire with co2 gas and with the welder turn up as high as it goes the weld just beads up without any penetration and I was only...
Nov 18, 2009 | Welding Tools
Welding Tools Logo
97 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
