Question about Garden
Air filter for Dynamac DY 41 chainsaw? - Garden
    Sergeant:
  • 340 Answers
Nigel you could try Central Spares on the net
Posted on Nov 17, 2013
2 Suggested Answers
  • 2239 Answers
SOURCE: Husqvarna Chainsaw #41
The air gap should be set to 0.3mm, the spark plug gap should be set to 0.5mm
Posted on Jul 07, 2012
How to clean air filter?
Hi Sharon!
If you have a paper air filter it will need to be replaced, rather than cleaned.
However if you have a foam air filter you can wash it in mild detergent and allow it to completely air dry and put it back into your chainsaw.
Here is a video about how to replace the air filter on a chainsaw, most are pretty similar, so if it's not quite the same brand as yours, it should give you the general idea.
Best of luck!
Replacing the Air Filter on RedMax Chainsaw
Chainsaw Air Filters I've also included a page to find replacement air filters for your chainsaw!
Sep 27, 2015 | Garden
How to change the filter
I'm assuming you mean air filter? If so, here is a video on how to change the air filter on a Husqvarna chainsaw, and a Redmax chainsaw, all of them are pretty similar so hopefully this will help you out!
Replacing the Air Filter on Husqvarna Chainsaw
Jul 08, 2015 | Garden
Proper fuel mixture for Dynamac DY 51?
you would be safe to run a standard 25:1 mix 200ml of 2-stoke oil to 5 liters of petrol/fuel/gas.....(5000ml divided by 200ml= 25) most 2 stoke oil is able to run at 50: 1 mix ...instuctions on what oil ratio should be used are always displayed on the oil bottle you buy for aircooled 2 stroke engines....
Dec 03, 2013 | Garden
Exact mixture for Dynamac DY51 chainsaw?
need a fuel line diagram for a homelite 330 chain saw
Dec 02, 2013 | Homelite Garden
Air filter for Dynamac DY41 chainsaw
if its a two cycle engine the only filter it really needs is a fine mesh brass screen over the intake , micro particulate dirt will go straight thru the carb and combustion chamber with no problems , four cycles they require a nice oiled foam filter that can be purchased new or made from a used bit of pkg foam and pair of sharp scissors , a squirt(not soaked) of bar chain oil into it and its good to go , as the carbs and cylinders will be affected more by small parts of dirt
Nov 16, 2013 | Garden
My Husqvarna 41 will run fine for a while (up to 3 tank fulls of gas) then other times it will start and run but then bog down like under a load (but I just holding it and not cutting anything. Other...
Does this describe your problem.? 'Engine does not deliver full power or runs erratically'
Possible faults - Muffler carbonized, Piston rings leaking or broken, Secondary air seepage through leaking gaskets on carburetor spacer flange / poorly mounted or faulty manifold.
Aug 04, 2013 | Husqvarna Garden
HUSQVARNA 41 CORRECT FUEL FILTER TO BIG FOR MY FUEL LINE IN TANK--DO I NEED TO GET BIGGER FUEL LINE??
you can get saw specific parts from a Husq. dealer or you can make shift something to get you by. the key is to make sure the hole in the tank is slightly smaller then the diameter of the hose to ensure there is no air leak there. I drill the tank hole out a size at a time until I have to force the hose in that will fit snuggly on the carb inlet then replace the fuel filter with one that fits the line
Mar 20, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
Jul 07, 2012 | Husqvarna Garden
Husqvarna model 41
Try changing the spark plug. Maybe it is bad and does not have enough spark . You may also want to check if the carburetor is getting gas . It seems that it probably is not . By the fact that you have to spray stating fluid. Check the hoses, filters, and the choke. Remove and clean the fuel filter and air filter . And by all means , check the ignition switch. That it is on and working .
Dec 19, 2011 | Husqvarna Garden
Garden Logo
97 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
