Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
TheOven was on Cool after self cleaning now it shows FSEL and keeps beeping
Our Thermador oven starts to beep when you shut it off and the way we are getting it to stop beeping is to set up a fan in front of the open oven to get it to cool. This stops the beeping after 10 m
Check if the internal ventilation fan is running. It is intended to cool down the oven exterior. Some units made 2004-2007 can overheat during self-cleaning.
Oct 14, 2014 | Thermador C301U Electric Single Oven
After cleaning both ovens have received F2 code Replaced sensor on one and now sensor is bad on the other one. theoven i replaced the sensor on continues to work but i am still getting the beep and F2...
most likely you have a bad computer board or clock assy. same thing,when you self clean the oven it gets up to 1000 degrees and can and will damage the electronics in the oven,after the things i've seen i will never use the self clean again,i clean my oven with an sos pad and hot water usually it's just the floor that gets drips on it,i take the racks and floor out and clean them by hand,if anything on the walls i scrub it out,don't use the self clean on any stove the extra heat kills them.
Nov 01, 2017 | Jenn-Air JJW8230D Electric Double Oven
My oven went thru the self clean cycle then started beeping. E1-F-5 shows on the screen and the door is locked and no matter what I do or push it just keeps beeping. I have unplugged it to make it stop....
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 19, 2011 | Kenmore Ovens
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
How do I use the self cleaning oven
Remove theoven racks first. Close door and set for clean mode. When time comes up set for 3 hours. Do not leave house while it is in self clean.
Jan 29, 2010 | Frigidaire Ovens
Self clean results in f9 and beeping
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Oven keeps beeping and displaying F1
this code is suggesting that you might need a control board.
Jun 21, 2007 | Magic Chef 9815 Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
51 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
