Question about Minolta EP4000/5000 CS/PRO Copier
Code c0070 machine ep4000 - Minolta EP4000/5000 CS/PRO Copier
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
The toner hopper needs to be cleaned , the hopper motor is not turning
Posted on Nov 21, 2013
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
Malfunction code C0070
mam/sir Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Jul 09, 2012 | Minolta EP4000/5000 CS/PRO Copier
Paper jam and give code C0070 at the screen. Model Minolta 4000
Hi this is a standars problem you will need to take apart the back of the toner hopper where the toner goes in the drive motor or worm gears will be damaged and will need to be replaced or the motor some times you just need to clean around the sensor toner hopper sensor and it will fix the issue
Feb 25, 2011 | Minolta EP4000/5000 CS/PRO Copier
C0070 machine trouble
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and if needed open then close the front door to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Minolta EP4000/5000 CS/PRO Copier
MACHINE SHOWING THE 0070 CODE PROBLEM
If the code comes back after the cartridge is re-installed then there is either a problem with the cartridge or with the toner bottle drive.
Jun 30, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error code c0070
Toner bottle rotation failure. I have a tip posted here at Fixya that deals with this code. Here is the link for you.
http://www.fixya.com/support/r3798733-konica_minolta_copier_service_code_c0070
If it works please return to this post and provide feedback.
Thanks.
Jun 21, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error code c0070
A error code C070 has to do with the toner hopper motor. Did you just put a new toner in. If so, carefully remove it and turn the copier off & close the front door & turn it back "ON" and let the copier come to "Ready". Once it is ready, reistall the toner bottle and close the door and see what happens. If it is not cleared you most likely have a problem with the "HP" flag for the toner bottle. Good Luck..
Oct 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
It is showing error code c0070
Insert correctly the toner cartridge,open the front door and press the service/trouble reset switch placed in the top left side. and close the front door.
Oct 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta 5000 copeir
the only code that i see in the service manuel is : c0070, c0071 and c0072
All of these's code refer to the toner replenishing, check if your bottle of toner is correctly position....
To make sure, take the bottle out and close the front door, the copier replace the mechanism correctly, after that replace the bottle to it's position and close the front door....Please let me know !
Mar 27, 2008 | Minolta EP4000/5000 CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
26 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
