Ryobi Multi-Volt Battery Charger
Problem for Ryobi Multi-Volt Battery Charger
Ryobi Model 1412001, 16vdc, 2A
By dave4341 on Oct 07, 2007
I'm trying to determine if the batteries or the charger is dead. Neither battery will hold a charge, and when I put them in the charger I get both the Charge Plus(Yellow) and the Fully Charged(Green) indicator lights. There is voltage (24.2 vdc) and current present on the charger.
The batteries are #1314702, 14.4v
Any advice would be appreciated!
Thanks,
Dave
Comments:
Oct 07, 2007
- If the charger is displaying two states at the same time that indicates the problem might just be the charger. That is why I asked for help troubleshooting the charger.
Maybe next time, you could actually read what was written before you jump out with a smart-mouthed response.
If this is the level of professionalism that is normal for this site, you won't last long.
Same Problem
Apr 13, 2008
-   What's the story?-   FuckYaMom
Dec 30, 2007
-   I have a Ryobi 18.0 volt charger #1423701. It has worked perfectly until last month. When I put a battery in to charge it the Charge Plus (yellow) and the Fully Charged light (green) both come on. The message on the front of the charger states if both lights are on for more than 15 minutes to see the manual. Un fortunately, the manual is has been lost and I don't know if the charger is bad or the battery is bad. It happens with 2 batteries that I have ran all the way down. Can you help me. Thanks, James Neal-   Guest
Best Solution
posted on Apr 14, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I found out the probem is the battery, not the charger. The cells of the batteries build up corrosion on the terminals inside and won't charge any longer. There's a guy on ebay who sells a method of revitalizng the battery. I tried it, it works.
Solution #2
posted on Apr 13, 2008
Very Helpful)
FuckYaMom
Rank: Apprentice
Rating: 95%, 2 votes
Anyone figure this problem out yet?
Was this helpful?
Yes
No
Solution #3
posted on Sep 16, 2008
Helpful)
scottlauer
Rank: Apprentice
Rating: 84%, 3 votes
Same problem here...Where in the hell are the serial #'s located anyway? I don't have any info on my batts listed on them except P-100 and "G0444" and a rep told me via email that neither one of these are the #'s they need to release warranty info to me....
Whatever....S'why I just bought a Dewalt 5 pack...Bulletproof.....
Was this helpful?
Yes
No
Solution #4
posted on Nov 02, 2007
Somewhat Helpful)
Valk_Driver
Rank: Apprentice
Rating: 76%, 2 votes
I've open the charger and found that Q4 is open. But they have removed the part number from the component so you can't get a replacement.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Ryobi Multi-Volt Battery
Questions and Unsolved Problems for Ryobi Multi-Volt Battery
Do you recommend Ryobi Multi-Volt Battery Charger?
Answer
Answer
Yellow & Green Lights stay on. battery is fully discharged.
Answer
One of the front power jacks will not work. The motor side works great. The orthe side the gear on... (More)
Answer
I lent my Ryobi 18 V batteries and flashlight to a friend during a power failure. When they were... (More)
Answer
i get a yellow light with some batteries
Answer
Probably in the wrong cattegory but I need to find the tp2 mkv trailer pack- manual. As I want to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ryobi Multi-Volt Battery...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
