Question about JVC TH-A25 System
Disk tray does not open
I press the open button but it doesn't respond. Can anyone help?
A disk is stuck in my Harmon Kardon player. The door will open and close and I can see the disk but cant' get it out.
turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
Sep 02, 2012 | Televison & Video
When i press start button on my Canon Gp225, it doesnt respond.. it dont even give any error msg also.. i tried loading more papers n closed the paper tray properly also.. tht gives proper sound also.. but...
if the start button doesn't responds could be that the microswitch/contact of start button needs to be cleaned/resoldered/changed.
You can try to apply small ammount of wd40 on the edge of start button. In some cases helps as first aid.
Call service!
Hope that helps!!!
Aug 29, 2011 | Office Equipment & Supplies
Unit on standby mode only, the dvd rack didnt open when open button was pressed.
Turn off and unplug at mains Plug back in and turn on press standby button so power light come son. If pressing open button on player (rather than remote) doesn't work it may be a disk that is not sitting properly in the tray. You could try sliding a very thin blade (preferably something with an insulated handle!) gently in the top of the tray to press the disk downwards whilst gently prising under front edge of the tray with a small screwdriver. If you can manage to press the open button at the same time as doing both these things it may help.
If that fails to solve the problem it may be a broken drive belt or worn cogs in the tray operating mechanism. DVD players are so cheap these days that repair is seldom worth the expense.
Feb 23, 2011 | Philips DVP642 DVD Player
Tray won't open.
hello,
the reason the tray wont open is because there is a problem on the mechanism that controls the opening and closing of the tray.
most likely the rubber that assists in opening and closing the disc tray.
to fix this, unscrew the player, turn it on and press the open button, it'll respond and stop.
you'll see a kind of mechanism that carries the tray, its engine is by the side of the tray.
when the tray stops responding after you've pressed the open button, try to carefully sit the engine properly and press the open button again and it will respond.
if you cannot do that on your own,try to take it to a service center for further repairs.
take care
May 30, 2010 | JVC DR-MV100B DVD Recorder/VCR
Wondering if anyone is any good with lite on shm 165 drives? Been trying to figure out why it wont open the disk tray. No disk inside, pressing the button makes an audible clunk noise. Pushing the pin...
Problem found on mine: tray opening mechanism is belt driven, while others are gear driven, belt tends to stretch with time and slips on motor pulley, gears do not. Just cheap built. Remedy= Belt can be removed from front with open tray, soaked in rubber rejuvenation liquid for few seconds, cleaned and dried, re- installed on pulley.
It works now, but for how long, I have no idea.
Aug 15, 2009 | Lite On SHM-165P6S DVD RW Dual Layer...
Pioneer DVL v888 disk tray will not open. There is a disk in it.
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Apr 05, 2009 | Pioneer DVL-V888 DVD Player
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
We have the RCA RS2767i Home Stereo with 5-disc changer and ipod dock. The CD Tray won't eject or shuffle...everything else works fine. It seems the disc tray isn't responding to anything. We read in the...
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Fred
Dec 05, 2008 | Audio Players & Recorders
A disk is stuck in the tray of my sony DVP-NS305 player. The disk tray will not respond to either the hand piece or the button on the player itself. The word "Locked" comes up on the display. How...
Unplug power cord, and whenb you plug power back and restart the DVD, keep pressing repeatedly the eject button on the unit.
Do this a couple of times.
If it does not work you will need to take apart the unit to take out the disk. In this case consider calling a qualified technician if you are not sure about how to do it.
Oct 04, 2008 | Televison & Video
DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
http://www.ryan.com.br/prod_dvp642_ejection.htm
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
JVC TH-A25 System Logo
26 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
