Kenmore elite quiet pak 2
About 10 years old suddenly starting to make VERY loud banging noise seems to caused by drum's extreme movement during spin cycle.... help, can we fix this without too much $$$
  • Aimee W
    Aimee W Nov 16, 2013
    sounds like from my research may be bearings? how would I check to see if it was anything else?
  • Bernice Wartella
    Bernice Wartella Mar 02, 2014
    changing the springs
    Problem Solver:
  • 10 Answers
No it is very expensive to repair. You have to buy the whole rear portion of the outer drum if it is the bearings. Or a tub spider which holds the inner tub to the spindle that spins it. it is a very labor intensive repair. you would also need the outer tub seal/gasket for reassembly. If you are a skilled mechanic you may be able to repair it cheaper than a new one, but be prepared to spent the better part of you weekend working on it.
Posted on Nov 17, 2013
  • 249 Answers
SOURCE: Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Posted on Dec 17, 2007
kjmac
  • 97 Answers
SOURCE: My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 19, 2008
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 14, 2008
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
SOURCE: Loud dry sounding spin cycle
I had the same problem with mine. The noise was verry loud towards the end...2 years I was a happy camper with my top of the line Cabrio, and then started to do the noise, a friend who work on washers told me that it was the transmission and to let it bust it self and then fix it. I have a home service warranty that covers the washer and they send a tech to fix it, he fix the problem with the transmission but now I have a problem of UL Unbalance Load all the time and I have to be moving the cloth around and move the knob to drain and spin all the time to get the the machine to drain the water. good luck with your problem
Posted on Jun 26, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore elite oasis dryer quiet pak 2 making loud screeching noises-
Either your glide pads that the front of the drum rides on are worn out, or the rear drum bearing are worn out
Mar 24, 2011 | Kenmore Dryers
Kenmore elite HE5t quiet pak 9 washer kocks when spinning. I thought something was lose but did not find anything. it will run to completion but get very loud for a short time. Is there some kind of...
I think possibly your machine is not on a level surface. Try rocking the machine, if it wobbles, the feet need adjusting to level the machine. It will cause damage in the long run if not levelled.
Dec 09, 2010 | Washing Machines
Kenmore Elite he5t sounds like a jet engine getting ready for takeoff during the spin cycle. It is extremely loud. Not sure why it all of a sudden started doing this.
Ahh yes, hopefully it's less than a year old. This is likely the main bearing located within the plastic tub. If it has sounded like this for quite some time, you will need a few new parts. The plastic tub (or "tub kit") and the stainless steel drum (which includes the shaft that the bearing rotates on). When did you buy it? If its under a year old, labor will be warrantied with the parts, but the parts themselves should be under warranty as they have a 10 and 25 (or lifetime) year warranty each.
Good luck! We just had this fixed, but now have a new problem. the front button panel will not light up. :(
Feb 19, 2010 | Kenmore Elite HE5t Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
hiya
hope this helps
Aug 19, 2008 | Washing Machines
Kenmore Front Load Washing Machine
warranty is free of charge the only they may charge is material they use .
Dec 14, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
