Question about Refrigerators
Samsung Refrigerator water filter bypass cap - Refrigerators
SOURCE: I need to bypass a filter in RS267LASH Samsung refrigerator
From the Samsung Online FAQ for my RF266AASH
Can I Use the Water Dispenser Without a Water Filter? spacer.gif The water and ice dispensers will work without an AquaPure water filter installed. The water filter housings are designed as rotary valves that allow the water to bypass the water filter whenever there is no filter or the filter is not in the lock position.
Models designed for use with the AquaPure water filter are shipped with a cap in place to cover the opening and keep it free of debris prior to the installation of the water filter. It is not necessary to have this cap in place for the unit to bypass the water nor is it intended to plug the housing to prevent leaks.
Note: This does not apply to the Quatro Convertible models. The filter must be installed on this model.
Posted on Dec 15, 2008
BIKER T
  • 909 Answers
SOURCE: Filter bypass for lsc26905TT
locate water filter bracket(normally in fridge compartment), then use screwdriver to remove from the frame. You will see two plastic pipes connected to this bracket. one will be water in and the other water out. pull the two off the bracket and join them together. (be inventive). Connect your RO system to the main inlet after original water supply is removed. Remember, your "filter to be replaced" light will still flash after a period as the fridge has its own software, counting depressions for cartridge replacement. (you would painstakingly have to reset.}
Posted on Jan 30, 2009
SOURCE: I can't get the bypass cap off to replace the
I just got my whirlpool fridge and I'm having the exact same problem! The blue cap appears stuck and I'm afraid I'll break it if I force it with a tool. Please post a solution if you get one - I'll do the same. Thanks.
Posted on Oct 30, 2009
  • 1891 Answers
SOURCE: how caN i BYPASS THE FILTER ON lg refrigeraTOR
almost all filter model have a by pass cap that to install it just remove filter and install the cap / its as easy as replacing the filter it self . you will have to order it from l g or your parts supply . ****
Posted on Jan 08, 2010
Testimonial: "I have asked everyone and no one has had a solution, til now.. Thank You very much.."
SOURCE: Where to get bypass plug/cap for LG Refrigerator
I have been searched for awhile, no LG by pass for 5231JA2006A. I tried to modify the pipe at back of the refrigerator. My ice make did not get water and water dispenser works. Looks the diagram.... like this... ( by guess) ....
From supply ( bottom of the refrigerator), goes to top into filter. From filter, one goes to ice-mater. One goes back out to back and connect to water dispenser ... This sound not logic.... But looks like this.
I think I need to cut a used water filter and sealed inside to make a by-pass.
Posted on Jan 17, 2010
How can I bypass the fridge water filter on my Samsung RA4287HAR refrigerator?
I know your model is Samsung but on whirlpools when you remove the filter it automatically bypasses the filter through the filter housing I would try that with someone that can turn the water off before you do it just in case I'm wrong about Samsung removal of the filter should allow it to automatically bypass otherwise you will have to buy a I believe a 5/16 Union and just bypass the two lines in and out where you can reach him on the outside
Appliance 911 Sea Breeze
Dec 02, 2015 | Samsung Refrigerators
How do I remove a refrigerator water filter bypass cap?
It should twist about a quarter-turn counterclockwise - like from the 3:00 position to the 12:00 position - then pull straight out. It fits the housing exactly the same way as the filter fits it.
Jul 25, 2014 | Fisher and Paykel Refrigerators
Can't get blue bypass cap off to put water filter
are you sure what you're turning is a bypass cap? KitchenAids don't usually have bypass caps.
If it is a bypass cap though, make sure you're turning to the left. It could be tougher because it's under pressure, so turn the water off going to the fridge and run the water out the dispenser if there is any.
Mar 09, 2012 | KitchenAid Refrigerators
How to install filter bypass plug (SmartWater)
the smart water filter twist out lik a oil filter on a car . and the bypas ( cap ) trun back on just like the filter that you just removed . .open both doors . when changing filter . filter cap ( bypass comes with instructions .. mm
Jul 03, 2010 | Kenmore 57029 Side by Side Refrigerator
I have an amana refridgerator with the ice maker and water dispencer. Neither one is working anymore and I was wondering if you could help in this problem?
Use the blue bypass cap which came with your refrigerator and check to see if the water filter is clogged. With the bypass installed you should get water from dispenser. If no water even with the bypass cap installed, check your water source and make sure it is turned on and no kinks to the connection line to the refrigerator. If you are 100% sure your water source is good TO the unit, then your Filter/Head assembly is not working properly.
Mar 29, 2010 | Amana 22.6 cu. ft. Side-By-Side...
is there a way to bypass the filter on a lg refrigrator?
Jan 07, 2010 | LG LFD21860ST Stainless Steel Bottom...
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Samsung Refrigerator side by side water is dispensed really slow. It will take 3 minutes to fill a glass.
Change your water filter, you should change your filter at least every year or it will start to grow bactria. If you still have the bypass (little plastic cap) you can us that in the mean time to get better water flow, it goes where the filter goes
Jul 07, 2009 | Samsung RS2630SH Side by Side Refrigerator
Water filter on refrigerator not working. Samsung
This link will take you to the Samsung support site. There you can find the instructions for replacing the filter....if the filter is not properly aligned, the water bypasses the filter
Jan 30, 2009 | Samsung RS2630WW Side by Side Refrigerator
Nov 21, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
