Question about KitchenAid KSSC42QM Side by Side Refrigerator
Condenser fan knocking
Over temp fault code
  • KitchenAid Master
  • 842 Answers
First of all, over temp light can be cause by the fan motor knocking, possible bent blade from cleaning. Was the unit recently cleaned? If so, you will need to correct this issue before you loss the compressor! If temps don't recover within 24 hrs, you will need to have the unit checked. Is the temp alarms sounding and or the red temp light flashing? Are you hearing a faint beeping noise from the top portion of the unit? the reason I ask this is when you have a fan issue you should have a alarm to advise the owner of a temp issue.
Get back to me with you findings so I can help.
kidlmo@msn.com or gere@taylorsappliance.com
Good Luck,
Posted on Nov 17, 2013
Condenser fan is knocking
Sounds like you need to clean off the fan blades. Over time the fan will build up so much dust it can interfere with the fan cooling the condensing coils. If the fan can't keep the coils properly cooled off the temperature in the refrigerator will rise. Make sure to unplug the refrigerator before cleaning the fan. Of course it could be that your condensing fan motor is just going bad (bearing etc.) If you are not comfortable checking the unit yourself contact an appliance service company.
Nov 16, 2013 | KitchenAid KSSC42QM Side by Side...
Restricted perfomance dash message
this warning can be flagged by lots of reasons you really need to get the fault codes out of the engine control module but the common causes i have found after working on these cars for a few years are air leaks after the mass air flow sensor, sticking throttle butterfly in the throttle body, the throttle itself, lamda sensors, and knock sensors, and because the temp gauge does not give you a true temp reading the engine could be overheating the clue to that is the rad fan always running
Apr 19, 2013 | 2001 Jaguar XJ8
SAMSUNG RS2534WW CONDENSOR FAN NOT WORKING
Was the motherboard replaced because the temp was too high? May be the condenser fan was at fault all the time. Check you have power at the fan. If you have, replace the fan. If you have not, take a live from the compressor to the fan. This will bypass any hp or fan speed control switch and run the condenser fan with the compressor.
Apr 20, 2012 | Samsung RS2630SH Side by Side Refrigerator
Spark knocks going up hills also temp gage not working
What do u mean by spark knock? Missfire? Temp gauge not working could be a few things, sender fault, no water, gauge fault or wiring. Check u have water in it. Then find the sender and earth it out, gauge should go all the way up, if it does replace the temp sender, if not it's gauge or wiring. Let me know about the spark knock.. Not sure what u mean
Oct 30, 2011 | 1990 Ford F150
Toyota 4runner 1994 engine codes 12,52,71 what are these
Code 12 Engine revolution signal missing
Code 52 Knock sensor fault
Code 71 EGR system malfunction
May 04, 2011 | Toyota 4Runner Cars & Trucks
Outside condenser fan won't run. I have pwr going to the contactor. The fan spins freely by hand. When I turn it to cool I get high and low lights illuminated on the circuit board. What do these mean??
You did not mention if the compressor ran when you depressed the contactor. The condenser fan is tied into the compressor wiring so if the compressor runs, so does the condenser fan. That is unless you have a winter kit in it which allows the condenser fan only to operate once it hits a certain temp. If you are getting error codes, I would say you have low refrigerant.
Apr 12, 2011 | Goodman GPC1342H21A Air Conditioner
GOLDAIR3 AIRCON MODEL RAS-90(3) SHOWS ERROR CODE F6 WHEN SWITCHED ON?
F-6 High discharge coil temp. due toover charged /condenser coil blockage/less rpm of fan motor in outdoor/non-condensable gas.
Purge out over charged gas/clean condenser coil/Replace fan capacitor./Releaseall gas and flush out the system,replace filter drier and vacumise & do gascharging.
Jan 19, 2011 | Heating & Cooling
When the aircon is being switched on, it does go on but cut's out and shows a error f6? Do not have a manual anymore
OR
As you don't mention model and brand name, please check with
F6 ambient temp.sensor of outdoor fault .- Replace it.
Helpful?
I'm getting error code F6 in kelvinator ac.As soon as i turn on the ac it works then with in a second i get the f6 error code
F-6 High discharge coil temp. due toover charged /condenser coil blockage/less rpm of fan motor in outdoor/non-condensate gas.
Purge out over charged gas/clean condenser coil/Replace fan capacitor./Releaseall gas and flush out the system,replace filter drier and vacuum & do gascharging.
Helpful?
Dec 31, 2010 | Heating & Cooling
I have just had installed a changhong cha25GTW split system it worked well for 1 week now shows F6 code on screen what is the problem?
F-6 High discharge coil temp. due to over charged /condenser coil blockage/less rpm of fan motor in out door/non-condensable gas.
Purge out over charged gas/clean condenser coil/Replace fan capacitor./Release all gas and flush out the system,replace filter drier and vacumise & do gas charging.
Dec 18, 2010 | Heating & Cooling
KitchenAid KSSC42QM Side by Side Refrigerator Logo
82 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
