Question about Bosch Dishwashers
Watertap message on Bosch dishwasher
"watertap" is displayed on the message board - the dishwasher is beeping and will not run
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 21 Answers
Hi.
Check the water supply first. Make sure water is actually flowing through the tap. Also check the inlet hose has not been squashed on installation as this is a common fault. All hoses should be routed along the bottom of the machine in the back where clearance is provided.
Regards Sam
Posted on Dec 01, 2013
3 Suggested Answers
I have a Bosch 44 dBA dishwasher and have been getting a watertap error. What causes this error?
You need to check the water supply into your dishwasher the water line may be blocked or frozen.
Jan 06, 2018 | Bosch Dishwashers
Bosch dishwasher say "Watertap" error message. What do I need to do to fix it.
possibly turn the tap on or ensure that water is flowing through the tap
Jul 14, 2016 | Bosch Dishwashers
Dishwasher starts to fill, then displays watertap error.
Not enough information to answer. Need manufacturer and model number before we can help.
Oct 30, 2015 | Bosch Dishwashers
Where do I check the watertap
where the water comes from usually
Jun 16, 2015 | Bosch Washing Machines
Watertap error
well what is the problem? cant help you if you dont as the right questions.
Jan 09, 2015 | Bosch Dishwashers
4000 series
There is some blockage in the pump unit and will need to be opened.
Usually the impeller is stuck or there is a blockage.
Will look something like the part on this link.
Drain Motor Assembly
Aug 02, 2014 | Bosch Dishwashers
Bosch Model SHX68T55UC/02: Display says "watertap" and will not continue to run. There is water standing in the bottom of the machine. What should I do?
The machine is telling you to check the water supply which fills your dishwasher. Check if the water pipe is frozen or blocked, do you need to turn on a tap to allow the water go flow to the dishwasher ? :)
May 25, 2014 | Bosch Dishwashers
She68t52uc flashing light which says E:15 and watertap
Not sure if this will definitely work, but i do believe this is a flood safety device. Try removing the drain pipe from the waste pipe, into a bucket or bowl, and empty as much water out as you can, then, with the pipe on the floor (will get wet), tip the top of the dishwasher backwards about 45 degrees, and hold for a few seconds. It may be that water/suds are still in the bottom of the machine, or the dishwasher detected this.
Dec 26, 2013 | Bosch Dishwashers
Dd603h my bottom drawer will not take in water - the top works fine. when i change motor the top still works fine and the botom still has a problem. it displays a watertap with a line over it sincerely...
The watertap with a line means the inlet water solenoid is faulty.
YOu will have to replace it with this part.
Please rate this solution if it was helpful otherwise post a comment and I will try to help futher.
Aug 11, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
2,963 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
