Question about Bosch 24 in. SHY66C05 Stainless Steel Built-in Dishwasher
"Watertap" message the dishwasher is displaying "watertap" on the message board - it will not run and is beeping
2 Suggested Answers
svicari124
  • 18 Answers
SOURCE: Watertap message on Bosch dishwasher
Hi.
Check the water supply first. Make sure water is actually flowing through the tap. Also check the inlet hose has not been squashed on installation as this is a common fault. All hoses should be routed along the bottom of the machine in the back where clearance is provided.
Regards Sam
Posted on Dec 01, 2013
Bosch dishwasher say "Watertap" error message. What do I need to do to fix it.
possibly turn the tap on or ensure that water is flowing through the tap
Jul 14, 2016 | Bosch Dishwashers
Soap dispencer leaving aoap behind
Check your water pressure. Remove the soap dispencer drawer, start machine, look inside the soapdispenser. You should see a good strong even spray of water. If not, the water pressure is low. Check water lines going from watertap to machine. Do you have good pressure at the watertap, but not when you connect hose? Check hose.
Reply if you need more help
Feb 15, 2016 | Washing Machines
Dishwasher starts to fill, then displays watertap error.
Not enough information to answer. Need manufacturer and model number before we can help.
Oct 30, 2015 | Bosch Dishwashers
Where do I check the watertap
where the water comes from usually
Jun 16, 2015 | Bosch Washing Machines
4000 series
There is some blockage in the pump unit and will need to be opened.
Usually the impeller is stuck or there is a blockage.
Will look something like the part on this link.
Drain Motor Assembly
Aug 02, 2014 | Bosch Dishwashers
Bosch Model SHX68T55UC/02: Display says "watertap" and will not continue to run. There is water standing in the bottom of the machine. What should I do?
The machine is telling you to check the water supply which fills your dishwasher. Check if the water pipe is frozen or blocked, do you need to turn on a tap to allow the water go flow to the dishwasher ? :)
May 25, 2014 | Bosch Dishwashers
She68t52uc flashing light which says E:15 and watertap
Not sure if this will definitely work, but i do believe this is a flood safety device. Try removing the drain pipe from the waste pipe, into a bucket or bowl, and empty as much water out as you can, then, with the pipe on the floor (will get wet), tip the top of the dishwasher backwards about 45 degrees, and hold for a few seconds. It may be that water/suds are still in the bottom of the machine, or the dishwasher detected this.
Dec 26, 2013 | Bosch Dishwashers
Hi.
Regards Sam
Nov 16, 2013 | Bosch Dishwashers
Dd603h my bottom drawer will not take in water - the top works fine. when i change motor the top still works fine and the botom still has a problem. it displays a watertap with a line over it sincerely...
The watertap with a line means the inlet water solenoid is faulty.
YOu will have to replace it with this part.
Please rate this solution if it was helpful otherwise post a comment and I will try to help futher.
Aug 11, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Bosch 24 in. SHY66C05 Stainless Steel Built-in Dishwasher Logo
97 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
