Question about Acer TravelMate 8572-6779 - Core i7 620M .66 GHz - 15.6in. TFT (S7820241) PC Notebook
Acer travelmate 8572 laptop screen flickers - Acer TravelMate 8572-6779 - Core i7 620M .66 GHz - 15.6in. TFT (S7820241) PC Notebook
  • 383 Answers
SOURCE: screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Posted on Dec 22, 2007
LaptopExpert
  • 458 Answers
SOURCE: my acer laptop travelmate 4052CLi blue tooth nor working-please h
Go To Acer.com / Support and Download your Bluetooth Driver/ Install it
Posted on Nov 17, 2008
thehumble1
  • 137 Answers
SOURCE: display flickers on acer travelmate 2410
so, did the new inverter fix the problem? and, when you were replacing the inverter, did you get to peek at the screen? ok ok, I'll make it easier than that. take your model number and search for "Acer 2410 LCD" on eBay, there are a lot of screens and none of them show a video cable that is glued or soldered to the screen. there are, in fact, a few video cables there as well, so my guess is that they are flat out lying to because 1) to get you to pay too much for repairs 2) because the person at tech support has no idea 3) they are sold together according to their parts list or 4) they really DO go together. My guess is that what they are talking about is a completely new LCD panel INSIDE a lid case with the hinges and bezel and all that. So SURE it's going to look like the cable is included, but if you just pop the back off the lid, it's probably about 10 minutes of work to replace the LCD without replacing the cable. I have to provide 2 caveats to this:
1) Acer is NOTORIOUS for glue. they love the stuff and may well have glued everything together inside the screen case.
2) I have no real experience with this specific model so I'm not sure.
It's just that every other screen ever is pretty much made of the same parts: an LCD screen with a backlight cable and a video input socket, an inverter if it's in the screen, mic, video camera, light, etc if they are in the screen, frame, back of case, and a video cable that goes from the video socket out to the mobo.
IS the display light flickering or the display image? that's important too. Good luck. it's my guess that it's either a bad connection a bad CCFL or was a bad inverter. the cables may have gotten pinched and that could be it too.
Posted on Feb 18, 2009
  • 13 Answers
SOURCE: volume button of acer, travelmate 2300 laptop??
just press and hold key Fn and press arrow up or down to change volume.
Posted on Feb 20, 2009
Andrezarion
  • 63 Answers
SOURCE: acer travelmate laptop's driver.
hi,
i found this website for you. i hope this can help you. Here you can find the necessary drivers for you notebook.
http://www.acer.com.au/acer/service.do;jsessionid=4A74252B67A5E12F0B9C3385F1F19B8D.public_a_14c?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3112&sp=page15e&ctx2.c2att1=92&miu10ekcond13.attN2B2F2EEF=3112&CountryISOCtxParam=AU&ctx1.att21k=1&CRC=3559666452
thanks
Posted on Mar 22, 2009
How to fix an automatically off after 5seconds of On
hi
kindly check first hadrdrive condition posible bad sector
May 07, 2014 | Acer TravelMate 8372, 8472, 8572 Charger,...
Driver
All drivers are available at the manufacturers web site.
Mar 27, 2014 | Acer TravelMate 8572-6752 15.6-Inch...
My acer 8572 travelmate one usb hub work but three are not showing device not recognized
try to clean up the contact with a cleaning contact solution,available in shops...
Aug 04, 2012 | Acer Computers & Internet
Acer 7530 screen flickers
hi
it flickers due to incorrect frequency setting.. LCD should be set to 60Hz. go to desktop, right click, graphics properties, display settings and set to 60Hz
Jan 02, 2012 | Acer Aspire 5630 Notebook
Screen is flicking again and agin Model is ACER Travelmate 5730
If the screen flickers when the lid is moved, then it is most likely the LCD ribbon cable has a bad connection to the LCD controller board. If it flickers without lid movement, then it is probably the inverter module for the LCD, but if it flickers constantly and especially if there are white lines that stay constant accross the display, then it may be an overheating or failing GPU. Check the air vents on the unit and make sure that there is no blockage if the latter is the case.
Hope this Helps.
Gill
Sep 24, 2010 | Acer Computers & Internet
Laptop screen brightness mild flicker will not stay bright
inverter circuit connector need to reconnect
or ccfl bulb not working properly change your inverter circuit
Feb 01, 2010 | Acer TravelMate 2300 Notebook
Acer travelmate 2410 broken screen
Hi
2 THINGS,one it could be the lcd cable has come loose behind the lid,
or the inverter is faulty.if your happy to take lid off an reseat the cable.
two.the screen cable maybe loose at the motherboard end.unplug power supply,remove battery,and unscrew keyboard,pull off cable an reseat the lcd cable.
i hope this may help
May 19, 2009 | Acer TravelMate 2300 Notebook
Backlight flickering
Matrix. Backlight lamp is flicking, you shoud change the matrix. If it is in guarantee, that is not you priblem, but if it is not..... the cheapest way is to find someone to chenge just the lamp. if you can
Apr 28, 2009 | Acer TravelMate 5720-6635 Notebook
Acer Laptop Screen Flickering
The flickering screen indicates that it is a backlight problem with either a faulty inverter or inverter connection problem. The inverter is usually located at the bottom edge of the LCD screen, and may have one or two connectors (one for the video info. and one for the inverter power or a combined connector) attached to the motherboard under the case near the top edge of the keyboard near the hinges. Reseating these connectors may solve your problem.
Jan 29, 2009 | Computers & Internet
Acer TravelMate 8572-6779 - Core i7 620M .66 GHz - 15.6in. TFT (S7820241) PC Notebook Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
