Question about Nokia 6303ci Rm-638 Uk Cv Steel
Can not clear text log
I try to clear and get code error every time on every log
    New Friend:
  • 56 Answers
Try resetting phone
Posted on Nov 17, 2013
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jun 30, 2012 | Computers & Internet
Unlock the code on Precor treadmill?
Dear Sir:
Please try with this Reset system for Code:
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
    • 5
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
If you need further assistance, please reach me. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 23, 2011 | Exercise & Fitness
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
SEQUENCE (cont.)
(t02)
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE DBVH512EFWW Dryer
NEED TO RESET CODE FOR TEXT MESSAGE LOG NOKIA 3555b
Try the default code which is 12345.
Please rate this solution so that we can help you and other like you.
Sep 02, 2009 | Nokia 3555 Cellular Phone
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Log in my mail problem
Call Yahoo Customer Care Number USA 1-844-414-4869
Oct 05, 2008 | Yahoo Mail
Error code
check your msg center to see if your number is correct
Jun 07, 2008 | Motorola Mobility RAZR V3
Deleting the recent log
thank u so much for trying to help. I guess my message wasnt clear enough though. The phone is not storing my "messages", I'm not having a problem with that, I can clear them, no problem. Its the "recent log" under the "add recipients" that does not clear. The "recent log" stores all the numbers you ever text messaged to. I want to clear the #'s that I've text messaged to, not regular calls, thats easy to clear. For some reason this phone stores all the #'s that you text to. If you can figure it out, i'll give u a million dollars!!! just joking of course.
thank u!
Jan 24, 2008 | Samsung SYNC SGH-A707 Cellular Phone
It won't let me im!
are you able to access your data services. If you dont have access to your mobile internet IM will fail. IM services use text messaging and wap access. Make sure you have both.
If you do try to log on with IM short codes.
Text in [Yahoo! ID] [password] to 92466. Do not include quote marks, brackets or commas. For example, if your Yahoo! ID is chatsalot77 and your password is 123456, your text should read : in chatsalot77 123456. Leave a space between in, your Yahoo! ID and your password, as illustrated.
  • You will receive a text message confirming that you are logged into Yahoo! Messenger on your mobile device.
  • To log out: Text out to 92466.
  • Alot of the time after this is successful you can log off through the menus in the phone and be able to log on successfully.
    Jan 19, 2008 | LG VX8300 Cellular Phone
    Nokia 6303ci Rm-638 Uk Cv Steel Logo
    Top Nokia Cell Phones Experts
    270rexton
    270rexton
