Question about Video Game Consoles & Games
Ghost recon PS3 Controller connection problem
I have just purchased a ps3 from a friend and i have been unable to get the ps3 controller to connect to the ps3 itself. I have tried a number of things: - Firstly checking that it is charged by pluging it in via usb and then holding the home button but nothing seems to work. No matter what I do it wont connect. I do also have the dongle thing and that is pluged in but still no joy! Please help!
  • 10 Answers
SOURCE: Logitech Cordless Controller for Xbox not working.
it looks like you may have to change your controller for a new one
Posted on Nov 18, 2007
  • 3 Answers
SOURCE: PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Posted on Jul 09, 2008
mumma_1
  • 903 Answers
SOURCE: ps3 controller does not turn on
try syncing it with your ps3 while it is connected to the usb. If it still does not work, then contact paypal to get a refund.
Posted on Nov 18, 2008
hk_danni
  • 67 Answers
SOURCE: ps2 controller buttons not working
what you can do is open the controller clean the board by using cotton buds with alcohol or cleaner you will notice accumulated dust preventing the buttons from touching the board you need to remove those.
Posted on Jan 26, 2009
SOURCE: Controller NOT Working Properly
I just came home to find this same problem. Four blinking lights on the wireless controller and the inability to sync the controller with my 360. On a whim I took out my controller's battery and then reinserted it after a few seconds. Voila! Problem solved. Controller works normally again!
Posted on Feb 04, 2009
Tip
Sync a ps3 controller to a diffrent ps3
<span> <li> <p>Using a PS3 controller charge cable (the cable that connects your controller to a USB port on a PS3), connect the PS3 controller to the console you wish to sync it with.With the cable still inserted, press the PS button in the center of the ps3 controller.The lights on the PS3 controller will flash for a moment, and then a controller number will be assigned to the new controller.Your PS3 controller is now synced to the console, and you can unplug the charge cable. Repeat these steps when you want to sync your controller with a different console.If you ever need to reset the Bluetooth connection of a PS3 controller entirely, locate the small pinhole on the back of the controller. By using a paper clip or other thin object to press the button inside this pinhole, you can reset your controller and its Bluetooth connection.<br /></li><span><br /><br /></span></span>
on Dec 06, 2010 | Sony Playstation 3 (PS3) Console
Ps3 slim doesnt reconize usb period,stuck at plug controller into usb and press ps button screen
did you try to connect the wireless controller with the usb cord or does that not work?
Sep 17, 2013 | Sony Playstation 3 (PS3) Console
My PS3 won't reconize any of my controllers, putting the cable in works, it find the controller, but when I unplug te cable the lights start blinking again and I can't use the controller, what to do?
Hmmm. It sounds like either your PS3's Bluetooth controller is on the fritz, or all of your controllers are on the fritz. Since I doubt ALL of your controllers are malfunctioning, I am betting it's your PS3. I suggest having a friend with a working controller stop by and test his controller against your PS3. IF your friend's controller works, then you know that the PS3's Bluetooth controller is working.
Second step is to check to see if the USB cable is transmitting a trickle charge to the controller. Again, using your friend's controller (make sure he brings his own USB cable with him), try charging his controller with HIS cable first. If after 10 minutes of playing with the controller plugged into the PS3 via USB, you unplug it and the controller still works, then the problem is most likely your own USB cable (it's apparently damaged in some way). Now run down the controller's battery and try recharging it with YOUR USB cable. If it fails to charge, then you know that all you need is a new cable. Just in case, make sure you test EACH of your USB ports. A simple replacement will cost you around $10.
Otherwise, your PS3's UBS port(s) are not properly working and you should send in your PS3 for repairs. As stated above, test each of the USB ports on your PS3. My 60GB one has 4 USB ports, so I would test all 4 of them before sending in the PS3. Then, if you want it repaired, make notes of which port(s) is(are) malfunctioning and send it to an authorized PS3 repair center.
Dec 24, 2010 | Sony BD Remote Control for Playstation 3
PS3 unable to switch from 720 to 1080 PS3 does not
if u go to system settings down to restore defualt settings you can reconect the controllers and reset the system to ur tv
Feb 16, 2010 | Sony Playstation 3 (PS3) Console
Gigaware remote for ps3 cant connect
I can not locate a Remote For PS3 By Gigaware now if its a controller Follow these steps
Connect to PS3
1. Turn on your console and plug the receiver into the first port on the console. The RX indicator on the receiver flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. The controller’s POWER indicator lights and the 4 port indicators flash.
3. The controller connects with the receiver automatically after about 3 seconds. If successful, the RX indicator on the receiver lights.
4. Press the PS button to assign a controller number. The corresponding port indicator lights.
Manual Search
If you are unable to automatically connect, try manual adjustment.
1. Repeat steps 1 and 2 under “Connect to PS3.”
2. Press CONNECT on the receiver. The RX indicator flashes.
6
3. Press and hold SELECT and L3 (left analog stick) on the controller simultaneously for at least 3 seconds. When the RX indicator stays lit, release SELECT and L3.
n Notes:
• Repeat “Connect to PS3“ or “Manual Search“ if the connection fails again.
• If you purchase a new receiver for the controller, but have previously been using it with the supplied receiver, you will have to follow connection steps again.
Reassigning a controller number
1. Press and hold the PS button for one second. The functional screen displays. Select “Controller Settings”, then “Reassign the controller.” Press X to confirm.
2. Use the D-pad to select the number that matches the controller’s port.
3. Press X again to confirm. The corresponding port indicator lights up.
7
Connect to PC
1. Plug the recevier into a PC’s USB port. The receiver’s RX indicator flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. If connection is successful, the RX indicator on the receiver lights and the 4 port indicators on the controller turn off.
Test the controller
1. Open the control panel on your PC, and double-click “Game Controllers.” Then click “Properties“ and the testing screen appears.
2. Press the buttons of the controller. After testing, press OK to exit. You are now ready to play games.
Troubleshooting
If the controller stops working at any time, or will not connect to PS3 or PC, follow “Manual Search“ steps on pages 5-6.
Dec 14, 2009 | Video Game Consoles & Games
Ps3 will not reconize intec in any way wireed or wireless. just invisible
CONNECTION A:
DO NOT INSERT BATTERIES INTO THE CONTROLLER; THE USB CABLE USED WILL SUPPLY THE POWER TO THE CONTROLLER.
STEPS # 1 – TURN THE POWER ON TO THE PS3 CONSOLE.
STEP # 2 – CONNECT THE USB CABLE TO YOUR PS3 CONSOLE AND CONTROLLER.
STEP # 3 – NEXT PRESSE THE SYNC BUTTON ON THE CONTROLLER, THE CONTROLLERS LED INDICATOR’S LOCATED ON THE FRONT OF THE CONTROLLER WILL START TO FLASH RAPIDLY.
STEP # 4 – CONNECT THE USB RECEIVER TO THE USB PORT ON THE PS3 CONSOLE.
STEP # 5 – WHEN THW CONTROLLERS LED INDICATOR’S LOACTED ON THE FRONT OF THE CONTROLLER START FLASHING SLOW PRESS THE HOME BUTTON.
WHEN THE CONTROLLER HAS ESTABLISHED A CONNECTION BETWEEN THE CONTROLLER AND THE USB RECEIVER ONE OF THE CONTROLLER’S LED INDICATOR’S WILL BECOME SOLID RED.
Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
Cant connect my ps3 control to any ps3
do you have the USB cable that connects the controller to the ps3, ( it looks like this: http://tech2.in.com/media/images/2007/May/img_5948_usb_cable_450x360.jpg ) its used for charging if you're more familiar with that method.
First make sure the controller you want to connect is TURNED OFF, then simply connect the controller to the ps3 using the USB cable then press the PS button in the middle of your controller, it should work
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
56 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
