Question about ASUS Tablets & eReaders
Extra cursor on screen at all times
There is a cursor on the screen at all times and I can't do anything with the tablet
My cursor jumps all over the place when I am typing. As I am in mid sentence I find that my cursor has jumped to another part of the screen then what should I do in this situation
Open the configuration panel (Classic view). Click on the mouse icon. Open the Cursor Options tab. Put a mark in the CheckboxHide Cursor during typing. You can also chek the box Show mouse cursor when I press thye CTRL key. You can also reduce the speed of the movement of the cursor. All these options are on the same TAB.
Jul 13, 2011 | Tablets & eReaders
The stylus for my gateway m280e is unresponsive, it is able to track the cursor across the screen but it can not select anything when double tapped, or write in one note? What could be the issue?
You can change the way the cursor functions. Here is how. From the "Start Menu", select Control Panel in the (right pane), next select Hardware and Sound, select, the "Mouse". In the Mouse, "Properties" (window) change mouse functions. "I hope this "Fix it"
Jan 24, 2010 | Gateway M280E
Cursor opening start menu and other applications by itself
Hi there, there are two possibilities here, one, the touch screen is compressed in 1 or more areas of the screen. two, it sounds like your PC has a prank virus in it that is causing unwanted side-effects. Try booting in safe mode on your tablet PC, and run a full virus scan.
Jan 18, 2010 | Dell Latitude XT2 Tablet PC
Fujitsu Stylistic 3500 Pen calibration in XP Tablet Edition
Well there is a few ways to try to fix it first with a usb mouse check that the resolution is at it's native pixel count. This can be found on the manufacture website. If it is already at that resolution ensure that the CIC XPen drivers are installed. Those should have placed a recalibration program in the control panel. If those both fail, try uninstalling the drivers and restarting, then reloading the drivers. Hope this helps! food luck and godspeed!
Jan 11, 2009 | Fujitsu Stylistic 3500 Tablet PC
Problem with the touch screen an stylus
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
Aug 21, 2008 | Itronix Duo-Touch Tablet PC
Screen rotates, pen doesn't
Is it maybe possible it is a hardware prob? maybe the directional sensor in the tablet was displadced.
BTW i have the same tablet and need an harddrive replacement/upgrade, how did you manage to do that? what kind of drive and where to buy? Viewsonic seems not so eager to help me out with that.
Best,
Fredrik
Apr 25, 2007 | ViewSonic Tablet PC V1100
Acer Tablet C300 Series - Cursor moving to Left
I?ve had a couple of Dells laptops do this and without fail the cause was flaky touchpad/mouse drivers. I would suggest going to the Acer website downloading the latest drivers for your mouse. If that fails try removing the driver and running with the Windows default drivers, that what I?ve been doing successfully on my company laptops for several years now. Acer driver download page, the web site is really slow so be prepared for a long wait. The closest match was the C300 so I?m assuming these are generic drivers for the 300 series. Use the pull down menus and select the following: -Select Product Line = Notebook -To the right of that select TravelMate C300 (way at the bottom) -Make sure English is selected and click on the search button. Once the drivers page opens go down towards the bottom and load for TM C300 touchpad drivers Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 19, 2007 | Acer TravelMate C302XMi Tablet PC
Tablets & eReaders Logo
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
