Question about Singer Sewing Machines
REX M607Z need spare bobbins. Can not find bobbin nbr or where to buy them??
Where can I find spare bobbins for REX M607Z machine pls???
    Problem Solver:
  • 11 Answers
Try Joanne's online or amazon.
Posted on Nov 21, 2013
4 Suggested Answers
fwadley
  • 482 Answers
SOURCE: Singer 9015 sewing machine - bobbin loading
bobbin goes under the door of the needal, the thead come out from the right to the left, thead goes in the first edge and up and out of the left, you need the needal to be treaded, turn the round right know till the needal goes in and out , pull the tread up and out together.
Posted on Nov 26, 2007
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
bilabon
  • 46 Answers
SOURCE: Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Posted on Sep 02, 2008
Where can i buy bobbin case for elna sewing machine
from a service agent for elna
from e-bay--- in the search or want to buy section , type in bobbins for elna sewing machine
from elna on line spares department.
Sep 03, 2015 | Elna Sewing Machines
For the dressmaker II, the first bobbin, I got through step 1-5 but where the does step 6 go BECUZ that's really trippin me, PLS tell me. And the instruction is not clear at all, I don't understand it
Hi Vicky, I hope this helps you:
1. Remove the slide cover plate by sliding it toward you, and lift
up the bobbin and the bobbin case from the machine.
2. Put the bobbin pin into the hole on top of the hand wheel and
place an empty bobbin on the bobbin pin (spindle).
3. Lift the large spool pin from the back of the machine and
place the spool of thread on the large spool pin.
4. Place the bobbin winder tension clip into the hole in the back
of the machine.
5. Pull the thread to the left and pass it through the bobbin
winder tension disc.
6. Insert the thread through the hole in the bobbin from the inside
out and leave about 3" of thread out. (ensure that the hole on the bobbin is facing upwards)
7. Hold the end of the thread and start the machine, either by
pressing on the start button or the foot control. After the
bobbin winds a few turns, stop the machine and cut the thread
close to the bobbin. (Cut the thread end that is protruding from the hole at the top of the bobbin).
8. Start the machine again and continue winding until the bobbin
is full or the quantity of thread is enough for your needs.
9. Stop the machine and cut the thread. Remove the bobbin from
the bobbin pin.
10.Take out the bobbin pin from the hand wheel and push back
the large spool pin into the slot in the back of the machine.
Good luck :)
Jun 21, 2015 | Euro-Pro Dressmaker 998B
Bobbin case keeps popping out
Hallo Rhonda
Pls chk your bobbin locking at fixing shaft grew or not. on bobbin a sliding locking plate locks at shaft. while keeping in case chk that is loked by pulling. if it dosent lock , change bobbin with spare one.
Jul 16, 2014 | White Sewing 2037 Mechanical Sewing...
Rex rx- 1804 bobbin case
check with the sewvacdoctor.com
Feb 21, 2012 | Rex RX-1804
I need a replacement bobbin for industrial rex 11-155r
Cutex Sewing has them online. Here is link to 100 but they have them in smaller quantity also. http://www.cutexsewingsupplies.com/servlet/the-2390/100-INDUSTRIAL-SEWING-MACHINE/Detail
They also have the needles DPX17 and Bobbin Cases too.
Jan 15, 2011 | Rex Sewing Machines
Bobbin Casing Replacement
slide de bottom windor under the foot and remove the bobbin casing, the bobbin shoud be inside. repace,it with a full one make sore that cotton runs oposit of the litell cut on the bobbin caing, if is a casing in same machins is only the bobbin. Good luck
Nov 25, 2009 | Rex RX-1804
Bobbin
Hi Sally,
Don't forget to change your needle too. It may not look bent, but it probably is.
Nov 06, 2006 | Rex RX-1804
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
