Question about Microsoft Windows Media Player
Error code:00003b68 comes up when trying to listen to music on my computer
Hi, Have an LG MP3 Model: FM37. When the MP3 player is turned on it displays Device Manager Code 0001 See the manual When connected to the computer, it displays Devce Manager Code 9001 See...
For the error 9001 ,i have a solution buddy..Try to format the device (from the General Settings) and the error message doesn't come up anymore...But The fact is you will lose all you data stored in it..hope this helps you..
Also i will try to find a solution for code 0001 too..Thank you!!
Regards!!..
Jul 23, 2008 | LG Audio Players & Recorders
How to put music on a gpx mp3 player?
Make sure your music files are in mp3 format, if you are trying to load wma's or some other format the player may not support it. You can also try going to my computer and finding the player, right click and then format the disk, but this will wipe everything off of the player
Nov 20, 2009 | Water Heaters
When i go to listen to my music, it comes up system file error
A lot of people have been complaining about this particular product. First of all, you have to format the player, but the instruction manual doesn't even mention this..
Plug one into the usb port and wait for it to detect. Then go to My Computer, and right click on the drive and Format. There is no 'firmware' to overwrite. It's just a flash drive attached to a controllable chip. Formatting it just makes it compatible with the system you are using so that files can be allocation the correct amount of space on your mp3 player.
You should now be able to copy songs over, although Protected mp3's WILL NOT PLAY ON THIS PRODUCT!!!
Unbelievable, I know, in this day and age..
Almost makes you want to download and install Soulseek and download 'normal' versions of the mp3's, doesn't it? Because they will always play in your mp3 player?
So first format the thing. The rest is up to you ;)
Hope this helps ;)
Season's Greetings!
Chris (ziraffa)
Dec 25, 2008 | Nextar MA933A MP3 Player
Rado
open the glove box u'll find it on the door with another code try the one with 5 digits
Aug 26, 2008 | 2007 Honda Fit Sport Hatchback
Need help quickly
i can't go to the next song cause it say's error.
Dec 31, 2007 | GPX MW3836 MP3 Player
Error Message
You have to synchronize your Sansa to a computer that has a current subscription to Rhapsody, and you have to sync the Sansa to that same computer at least once every 30 days, or the Rhapsody songs will stop working. Use a different music service that is free, or convert all of the songs to Mp3 format to get around the problem. If you get a subscription to another music svc, then you must maintain a current subscription with whatever new svc you choose as well.
Dec 27, 2007 | SanDisk Sansa e260 MP3 Player
My music reads error and it wont pop up when i plug it in
The only way to fix it is to erase all the downloaded songs, press the reset and start again.
Dec 26, 2007 | GPX MW3837 MP3 Player
Synchronize music
i had the same problem. all i did was format it and reload all of my songs and now it works perfectly. hope this works for u 2!!!!!
Aug 31, 2007 | SanDisk Sansa e260 MP3 Player
Microsoft Windows Media Player Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
