My wireless printer says it is not connected and it is as I have used it many times.
When I try to print , the computer says it is not conncted Wireless HP 30000 printer
  • 93 Answers
SOURCE: how to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
Posted on May 26, 2008
  • 93 Answers
SOURCE: HP 7410 off line with Vista & HPM8000 computer
Once right click on the printer icon and make it online and then clear the print que and then download and install the patch from the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-54112-1&lc=en&cc=us&dlc=en&product=391194&os=2093&lang=en
After installing the patch restart the computer and check for the result.
Posted on Jun 19, 2008
tipstir
  • 67 Answers
SOURCE: HP Color LaserJet 3550N wireless connection
Use the software that came with your printer. There is some sort of HP Admin that runs in your web browser that you can communicated with the Wireless Printer. The USB cable is use to install the drivers and software you want to use with it. Also backup in case of the wireless has issues you can still use the printer. If you're using a wireless router make sure it can see the wireless printer. But again you need to know what's the default Web Admin address and you say you know it.
So 1. open your web browser and type: http://192.168.1.2 in this example is what you would do. Your IP address will vary.
The manual or quick guide that comes with the printer should tell you want to do next.
Does it have wireless adapter card installed or just HP Jet direct card for 10/100? You might not have the wireless option installed as default. Check the connections to see what you have?
Posted on Jul 31, 2008
mbase213
  • 728 Answers
Hi jjank740;
First off, did you try to recycle your printer? Turn it off and back on again. Sometimes power outages can disconnect that printer. If that doesn't work. Go to the printer and access the system network configuration on the led panel. Type in the WEP number and password again, and let it search for the connection. That should do it. Once it's connected you'll see the blue wireless indicator turn on.
Good Luck
Mark
Please don't forget to leave a rating.
Posted on Feb 19, 2009
RickOz
  • 145 Answers
SOURCE: My wireless internet wont connect to my computer
If you click on Start, connect to and then select show all connections does your network show up? If not then I suspect your Windows Zero configuration service is not started. Goto control panel, admin, services and be sure it's started.
Are you using any type of security on the router like WPA or WEP? Look at the network settings of one that is working and be sure you are set the same on the one that does not work.
Also, if your router is using MAC filtering be sure your PC's MAC address is added to the routers list of acceptable MACs.
Try these and let me know what you find.
Posted on Mar 15, 2009
Trying to get an canon mx450 wireless printer to print. I may have pushed reset. I can get printer to say connected and computer to read green light,
Offering some ideas here: You have paper in it, all the doors are closed all the way and if laser printer, the cartridge is in all the way in. Still for some reason it may be off line. I confess I haven't used Microsoft windows for some time but can you go to printers from control panel and try a test page. Check the program you print from go to File--Print and see if the printer shown is the one that you are trying to print to (sometimes someone in office switches it), or printer is shown in print dialogue window when you hold control and press the P key.
Jul 08, 2016 | Canon Office Equipment & Supplies
I am using Windows 7 Professional and have a network computer connected to one of the computers. I am trying to install a Belkin 8236-4 wireless modem. It works fine, but it causes the network printer to...
very simple. change the ip of printer to same belkin router network.
like make it 192.168.2.55. becuase both on different so it will not print.
in case you have wired and wireless network both connect same time. it should print without any change.
Dec 11, 2017 | Belkin F5D8236-4 N WIRELESS ROUTER4PORT...
I have my Canon MX420 printer hooked up, my computer recognizes it's existence, and the printer prints fine by itself. However, every time I try to print from my computer via wi-fi, my computer says...
If your printer has the network cable plugged into it then your halfway there. Make sure that as well as having a hard line network cable plugged into your router, you need to connect the printer to the wifi signal as well. On your printer, push your settings button, scroll to your wireless lan setup, and connect to your router and if password protected, enter in the password and you should then be connected to you router, now try printing using your laptop or device through your wireless connection, and it should print. Please post back if you need further instructions or help!
Aug 24, 2011 | Canon Pixma MX420 All-In-One Printer
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
Ihave a dellp513w and some how i put the disc in that came with it trying to get it connected to the computer so i'am able to print from the computetr and it want work. The disc want connect to the...
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Uninstall the printer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
With your computer online, Insert the printer disk or try using the drivers located at...
Dell P513w Wireless All-In-One Printer owners thread
You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block printer communications.
Rick
Apr 19, 2011 | Dell 948 All-In-One InkJet Printer
Wondering what I need to print wirelessly from laptop with this printer
If you printer hasn't a built-in wireless connection and if you haven't a wireless router then -
You need a wireless router plus print server. Connect this print server to the wireless router with a LAN cable. Then the printer is then connected to the print server's printer port.
The laptop's wireless card is then configured with the router's wireless settings.
The laptop is then installed with the printer driver and the printer port needs to be changed/configured with the print server's IP address.
ALTERNATELY
If the printer is connected to a desktop computer on your home LAN and it is also connected to your wireless router. Then you can set this printer as A Shared Printer on your desktop computer, but this desktop computer and the printer has to be powered up for the laptop to print to the printer.
For instruction on setting up a shares network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Nov 16, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Will not print, can.t find printer
If you are not able to find your printer on your computer, then the simplest thing (but takes time) you can do is uninstall the printer using the companion disk that came along with the printer and install it again. This will ensure that all the drivers are well up to date and then you will be able to print again.
However there are another reasons for not showing printers in the Printers and Faxes folder in Control Panel. 1. Check your wireless settings on your computer. 2. Check the printer by connecting it using USB cable directly to your computer.
If it connects again using the cable, you may need to run wireless configuration once again using the same companion disk.
Cheers!
Mar 27, 2010 | HP Officejet Pro L7680 All-In-One Printer
HOW DO I USE A WIRELESS PRINTER WITH NO ROUTER. I WANT TO PRINT FROM TWO COMPUTERS, THAT BOTH USE DIAL UP INTERNET
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Signifcant delay when printing
Your post does not mention all IP addresses in use, and which devices use wireless. That information would be helpful.
Is it possible that you are getting an IP address from a router for your internet access, then when you try to talk to your print server it may be trying to assign an ip address too.
(Sometimes a wired computer also has wireless enabled, which can cause an issue when one ip address has already been received on the wired connection and a wireless connection is also trying to connect.)
Mar 29, 2008 | NetGear PS121 Print Server
Trying to set up a network printer with DELL TRUEMIBILE 2350...please help
using windows xp on all the computers, when you connect to the printer windows should automatically install drivers.
1. Goto My Computer, Click My Network Places (Explorer Bar).
2. Click View Workgroup Computers (Explorer Bar)
3. Find the computer that has the printer physically connected to it, open it
4. Find the printer and right click it!
5 Select Connect... and wait for the drivers to install.
this should install the print drivers and install the printer on your computer. the printer should now be available in print dialogs i.e. word etc etc and from the Control Panel > Printers window.
Nov 03, 2007 | Dell Wireless 2350 Router
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
