Question about Bush Televison & Video
Non recording of programmes
My DVD recorder suddenly won't record programmes.
  • 3 Answers
SOURCE: Recording from DVD recorder to disc
Christine,
1) Put a compatible DVD in the tray. (I have noticed that I must format DVD+R discs, but others are formatted okay for recording -- such as DVD-R and DVD RW)
2) Close the tray.
3) Make sure the player is set to HDD and not to DVD. It will indicate HDD, DVD, or SD on the LCD screen.
4) Using the remote press the "functions" button.
5) Select "copy" from the menu when it appears.
6) You will now see the list of programs you have recorded to the HDD. Highlight the one you want to copy and press "Enter" on the remote.
7) I think there are two confirmation screens that come up, press start or continue or whatever it says.
8) My recorder generally takes about 14 minutes at high speed to copy a two-hour program. If the program is longer than 2- hours, you must divide it into tow or more shorter segments for more than one DVD.
9) If you want to select several shorter programs (not to exceed 2-hours combined) highlight the programs individually pressing the PAUSE button on the remote. This places a check mark next to each of the programs. When you finish, press the enter button on the remote and go through the confirmations screens again.
10) If the DVD is nor rewritable, it will automatically run the "finalize" program. It takes about 3 minutes and runs after recording. This formats the DVD so that it can be played in non-Panasonic players. If it is a DVD-RW, they you must finalize it manually if you want to watch it on other types of players.
Hope this helps,
Nancy
Posted on Jul 22, 2008
SOURCE: LG RH1777S HDD/DVD recorder says
got to replace the DVD device. It costs 60 Smoola! Just got mine replaced.
Posted on Aug 20, 2008
SOURCE: samsung dvd sh873 recorder with
Did you turn the power off to finish the timer recording? Timer recording doesn't work with the power on.
Posted on Dec 30, 2008
SOURCE: I have purchased a Teac HDR2500T video recorder. I
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Posted on Sep 06, 2009
SOURCE: Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Posted on Jun 13, 2010
Will not record two programs simultaneously
make sure at least one recording is in DR mode
Aug 08, 2012 | Panasonic Dmr-XW380 Dvd Recorder
My logik L160STB11 freeview tv recorder won't record properly
mine did that then wouldn't recognise the hard-drive
Apr 25, 2012 | Televison & Video
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
Can I record programmes from tv whwn I have samsung dvd v5600
Afraid not! ... You need a Recordable DVD player to record TV programs....
The Samsung v4600 is just a DVD player, with no recording capabilities.
Sep 24, 2009 | Televison & Video
My lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
Can't finalising the recorded discs, and can't record at high speed from SKY box to DVD recorder.
instruction man available on line
plug the sky output cable directly into the recorder then press record
Jun 01, 2009 | Televison & Video
Unable to record e.g MOVIE from TV to DVD disc
Just record the shows to the hdd and when your there then burn the shows into the dvd from the hdd.the dvd is pretty small it wont hold many shows.
Apr 27, 2009 | Televison & Video
LG HDD/DVD Recorder RH177
Hi. I have this machine and it will only fast transfer if the original hdd recording has NOT been edited (i.e part deleted/divided/combined). This is also in the manual p51/52.
Hope this helps.
Adam.
Feb 06, 2008 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
16 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
