Question about Platinum Mydrive Cp 1Tb 2.5 Inch Hdd Usb 2.0 External Hard Drive - Black
My platinum usb hard drive is not loading - Platinum Mydrive Cp 1Tb 2.5 Inch Hdd Usb 2.0 External Hard Drive - Black
No usb boot setting in available in Asus laptop aptio utility version 2.01.1
You can't because the usb root hub won't work until the PC boots. You'll never get the pc to boot from the usb drive with that bios version.
Nov 15, 2013 | ASUS " 14"" Laptop - 8GB Memory - 750GB...
Seen as movable
If you change the Boot Device startup order with the USB port as the first boot device then you can boot up with an USB hard drive or USB Flash device.
If your hard drive is the first boot device then your USB hard drive will not boot up first.
Aug 01, 2012 | Transcend 750 GB 2.5-Inch USB 3.0 Super...
What is the Platinum content on a 3.5" platter
The hard drive is the component of the computer where data is stored. Each drive contains one or more platters or disks where data is stored on the magnetic surfaces. The amount of data that can be recorded on a given surface depends very much on the strength of the magnetic field generated by the surface layer.
Platinum enhanced magnetic alloy allows data to be stored at much higher densities.
Back in 1957 when IBM first introduced the hard disk, storing just 5 megabytes of data require fify disks, each measuring 24 inches in diameter. Sixty years later, a much smaller 3.5 inch disk drive is capable of storing over 500 gigabytes of data. An important process to achieving this remarkable increase in storage capacity is by adding platinum to the cobalt alloy to enhance its magnetic properties, allowing data to be stored at higher densities.
With so much digital content being created (at higher and higher definitions) and then shared online by millions of people over high speed broadband internet, the strong demand for higher capacity disk drives has resulted in more platinum being used in the manufacture of hard disks to enhance their storage capacity. The proportion of platinum in the magnetic alloy has gone up from less than 10 percent in 2002 to 35 percent in 2007.
Nov 29, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
How to upgrade new songs to my Platinum BMB-ONE HDD/DVD player
How to update songs (Hard Disk Model):
Method 1 - Single Volume Update Only
This method will require a Flash Drive.
Song Update data and Certification Key data will be written in the Flash Drive.
You can bring home the Flash Drive and be able to update the Platinum karaoke player by your own easily.
a. Bring a working Flash Drive to a Platinum Karaoke branch near to you and surrender it to our sales representative. Be sure to get a receipt. Your flash drive free space should be atleast 1 GB.
b. Our sales representative will then send your USB Flash Drive to our Head Office for processing
c. The process will take about 5-7 working days
d. Once you get your Flash Drive, ask for instruction on how to use the Updater
Method 2 - Multiple Volume Update
This method will require a USB Flash Drive and Hard Disk Drive in your Platinum Karaoke player.
Hard Drive will be re-formatted and be written with Fresh Updated data.
Certification Key will be written in the USB Flash Drive.
You bring home the Hard Disk Drive and Flash Drive, re-install the Hard Disk Drive in your Platinum Karaoke unit, and insert the Flash Drive to run Certification process.
a. Carefully disassemble Hard Disk Drive from the Platinum karaoke unit.
b. Bring the Hard Disk Drive and 1 USB Flash Drive (at least 1 GB of free space) to our sales representative nearest you (See List of Branches here)
c. Our sales representative will then send your Hard Disk Drive and Flash Drive to our Head Office for processing
d. The process will take about 5-7 working days
e. Once you get your Hard Disk Drive and Flash Drive, ask for instruction on how to finalize the Update process
How to Install the Update:
a. Make sure that the unit is switched off.
b. Attach the Flash Drive/Hard Disk/SD Card into the unit. For X2 model please note that MicroSD is not applicable for update.
c. Switch the unit ON.
d. Update will automatically run. Wait for the unit to automatically shut down.
e. Remove the Flash Drive/Hard Disk/SD Card. Switch the unit ON.
f. Update is Complete.
How to update songs (DVD Model):
a. Directly purchase DVD (comes with additional song list) from a Platinum Karaoke branch near you.
b. Play the DVD and enjoy your newly updated songs!
Nov 09, 2010 | CP Technologies USB HDD Platinum Series...
Laptop will turn on, but can't load recovery or driver disks and if i don't use those i get a disk read error press control alt delete.
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Sep 29, 2010 | MSI 915P Neo2 Platinum Motherboard
Platinum off old hard drive discs ?
Don't believe this is true. Hard drive platters are made of aluminum, coated with a magnetic material. not platinum.
Sep 20, 2009 | Computers & Internet
Bios don't boot on p7n platinum sli
check the voltage on the power connector going to the hard disk.
it should have 12volts in red and black wire and 5volts on the yellow and black wire.
the main problem the optical and hard disks can't be recognized is the low voltage supply the drives gets.
Apr 13, 2009 | Intel Motherboard
Platinum hdd back up problem
well...zou can find out about backing up data from help on your desktop..
Oct 18, 2008 | Platinum Syba SD-U2PLA-3ITE Series...
DVD X Copy and DVD X Copy Platinum
DVD X Copy Platinum can be activated 3 times, though if you need to activate again, you can request another activation via the online forums or phone. you can re activate it via the online site at http://www.dvdxcopy.com/
May 14, 2008 | 321studios DVD X Copy Platinum (200000)...
Platinum Mydrive Cp 1Tb 2.5 Inch Hdd Usb 2.0 External Hard Drive - Black Logo
Top Platinum Computers & Internet Experts
john h
MarcellusA
Level 1 Expert
Tom Chichester
Are you a Platinum Computer and Internet Expert? Answer questions, earn points and help others
