Question about Cooktops
Can I get knobs with indicator lights for a dacor cooktop , model#sgm464gg,serial#85464
Indicator lights for a decor cooktop, sgm464gg, serial# 85464
  • Cooktops Master
  • 842 Answers
Here is the breakdown I found for you SGM464GG
I hope this helps you, good luck
Posted on Nov 17, 2013
SOURCE: cooktop light stays on when cool
Please be more specific.
A.  What is the "plate cut-out"?
B.  How does one access it?
Posted on Oct 15, 2007
  • 110 Answers
SOURCE: Dacor PGM 304
ON DACOR AS WELL AS THERMADOR YOU HAVE TO TAKE ALL THE BURNER CAPS OFF AND INTHE CENTER OF EACH BURNER CELL YOU WILL SEE A RELEASE NUT THEIR ARE 3 TO 4 DIFFERENT TYPES BUT THE MOST COMMON REQUIRES 13/16 SOCKET OR A 3N1 PUTTY KNIFE TO UNSCREW THEM. BE VERY VERY CAREFUL IF THE NUTS DO NOT COME LOOSE FREELY DO NOT FORCE THEM!!! USE SOME LIQUID WRENCH AND LET IT SOAK FOR A WHILE THEN ATTEPMT AGAIN. OTHER WISE YOU WILL MANGLE YOUR GAS TUBE AND ORFICECES AND HAVE 7OR 8 PARTS TO ORDER INSTEAD OF ONE
Posted on Jun 01, 2008
SOURCE: my ge ceramic cooktop hot indicator light won't go out
I know that some people have mentioned that it looks like it's on, even when it's off. Depending on how the light hits it, it can look like it's glowing a bit. This would be normal.
Posted on Apr 01, 2009
  • 113 Answers
SOURCE: Popping noise and red light
it could be a switch, element or a short somewhere else
Posted on Apr 29, 2009
  • 1891 Answers
SOURCE: The cooktop indicator light on my Whirlpool range,
most cook tops the light that maches the burner is on if sw is on . if light doesnot fo off replace that sw . if only one light for all burners you will have to fint the shorted one.. good luck mm ..
Posted on Dec 12, 2009
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
The control knob on the left back pops and throw the breaker every time we turn it on. It also throws a spark.
I am having the same problem with similar model (all of the control knobs line up on the right side of the cooktop). I removed the controller that "popped" and then turned the breaker on -- it flashed in a different location (under the indicator light adjacent to the controller I removed). Just for additional fun, I turned on the breaker one more time and I got a flash under the controller at the opposite end of the controller panel. I am assuming that I have fried at least two controllers and an indicator light does anyone know what the source of the problem might be? Thanks!
Jul 26, 2011 | Jenn-Air JED8430 Electric Cooktop
I need to replace two blue indicator lights and I need directions
I have replaced several of the indicator lights in the control knobs.
Turns out that Dacor doesn't sell exact replacement lights (actually LED modules).
What I did was to go to a local electronics supply store and purchase Blue replacement LEDs and a current limiting resistor to connect in series. Replacement LEDs can vary in brightness depending on your taste ... I chose a super bright LED which makes the control knobs noticeably brighter. The value of resistor will vary depending on the LED you choose (brighter LEDs need slightly more current and as such the resistor value will be slightly less).
Once you've opened the range from the top (remove knobs, grates and burners) then remove a few screws and the entire unit opens with a hinge in the back.
Look over the LED light modules which shine just below each knob and fashion a replacement LED assembly.
Total material cost per LED unit was ~ $2-3 (LED, resistor, wire and heat-shrink tubing)
Jan 04, 2011 | Dacor 36 in.PGM365 Gas Cooktop
The 4 of the 5 knobs on my Dacor cooktop GGC365 have "locked up" and can't be turned on. Mechanism is supposed to depress and turn to left but I can't get them to move at all. There is nothing in booklet...
Hi, I know this is not a solution to your problem, but if you are not able to fix your cooktop, and decide to get rid of it - I will buy your the grates from it...
Sep 09, 2010 | Dacor Cooktops
My Dacor PGM365 knobs keep breaking off and I can't find a place to get replacements. do you know of a source?
http://www.reliableparts.com/ - DACOR refuses to fix the fundamental quality issues with the knobs. I've replaced a dozen in the past few years. I will never buy Dacor again because of the customer support refusing to acknowledge the issue.
Jul 20, 2010 | Dacor 36 in.PGM365 Gas Cooktop
The cooktop indicator light on my Whirlpool range, model RF265LXTY, won't go off, all of the knobs are in the OFF position. The hot surface light is off.
Dec 12, 2009 | Whirlpool RCC3024 Electric Cooktop
Why is the light burning on my Corning glass cooktop?
well there is some problem with ur knob u should replace it.
Jul 21, 2009 | Verona 34 in. CTG536S Gas Cooktop
DACOR COOKTOP PGM-3651S
The top of the unit must come off. I suggest a qualified Dacor tech.
Mar 15, 2009 | Dacor 36 in.PGM365 Gas Cooktop
I melted the knobs for my dacor cooktop and the model number for the cooktop is: SGM365S.  What do I need to order and from whom? Thanks, Sanford
You will have to order from a dacor dealer. Check with the manufacturer for a dealer near you. try 1-877-DDS-DACOR
Jan 28, 2009 | Dacor Preference SGM365SS Gas Cooktop
Dacor PGM 304
Mar 12, 2008 | Dacor Preference SGM304 Gas Cooktop
Cooktops Logo
87 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
